03-21-2022 02:07 PM
Can anyone tell me where we can setup the voicemail pilot number for webex calling.
Solved! Go to Solution.
04-17-2022 10:11 PM
Hey AJ!
Just to add to this, your actual voicemail will not work until you assign an internal extension for voicemail in the voicemail portal like you mentioned (calling-locations-voice portal). But I also found out something interesting: if you want to dial the voicemail pilot, if you just dial the number you place here in the webex calling voice portal, it won't log you in to your actual voicemail!
To login to your actual voicemail, enter your extension itself, it will take you straight to the voicemail pilot
03-21-2022 09:17 PM
ok I found it. It is under Calling>Locations>Voice Portal
04-17-2022 10:11 PM
Hey AJ!
