05-10-2021 02:26 PM
Is it possible to incorporate SMS in to WebEx Teams?
05-11-2021 06:59 AM
Thanks Jeffery, it is really helpful. I do see the SMS feature request already filed, and it's marked for future consideration on the roadmap, it would be helpful if you vote for it, and comment on your use case:
https://ciscocollabcustomer.ideas.aha.io/ideas/WXCUST-I-1236
I was curious though, does the Assistant Closed Caption feature help as well?
https://help.webex.com/en-us/n5eooo0/Use-Cisco-Webex-Assistant-in-Webex-Meetings
05-10-2021 04:07 PM
Hi Jeffrey,
was wondering if you can describe your use case for it? Also please don’t hesitate to submit the feature request on AHA.
05-10-2021 04:12 PM
