Access a Webex Room Kit web interface via the Webex Admin Portal
jimihendrix1
Is there anyway you can access a Webex Room Kit web interface via the Webex Admin Portal without having to be on the local network? As I'm trying to access one of our End points remotely without having to be in the office.
I did attach a screen shot.
Thank you!
PJMack
Level 7
Level 7
Unfortunately no, you have to be routable to the device to get to the Web GUI. Your two best options would be to see if you can get VPN access (this is what I do when working remotely), or a VDI session. Other than that you'll be limited to what is available in Control Hub as Jonathan mentioned.
Jonathan Schulenberg
No but you can set many (not all) xConfig settings directly from WCH.
