Can I register a DX80 or the latest Webex Desk Pro to a FREE Webex account?
mamatriagain
I have both a DX80 and a Webex Desk Pro (both courtesy of previous employer).  Now that I'm no longer working, I use these units as displays only.  Is there a way to take advantage of the external video and audio capabilities of these units on my Macbook (right not, they both come from my computer, but I would prefer to put in in clamshell mode), or possibly register the units to my free Webex account?
Thanks in advance!
davidfe
Alternatively to https://settings.webex.com/devices  , you can try adding your device using the Desktop version of Webex. It should generate an activation code for you.
davidfe
Try going directly to https://settings.webex.com/devices instead of https://settings.webex.com/main/devices , and see if the set up device button pops up.
ktwong
As long as you can sign into https://settings.webex.com and have the option to add a device, you should be ok. I found out if you have an account that is ~2 or 3 yrs old, you can see the device option. If your account was created this year, you won't see the device option.
Response Signature
