Cisco WebEx DX80 WhiteBoard on Prem
AbdulSakkeer
Dear All,
Is there any way we can enable whiteBoard feature on-prem registered DX80 end point (CUCM Registered). I can see only this supported on Cisco WebEx clloud.
AbdulSakkeer
Collaboration Engineer
You are right, the whiteboard feature is supported on Cisco Webex-registered devices only.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
chrisconnolly
Have you looked at Webex Edge for devices yet? That allows you to leave your devices registered on premises but take advantage of some of the cloud only features.
As I have mentioned earlier, the DX80 is already registered on cucm and all the features are working except whiteBoard feature.  As per the below link, it won't support on-prem registered devices and also noticed some other posts that it's on the road map, will be available within 3-4 months.
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/desktop-collaboration-experience-dx600-series/datasheet-c78-731879.html
AbdulSakkeer
What are the benefits of registering Cisco Webex Cloud with Dx80,
What added features will i get in Cisco Webex Meetings during the webex meeting call.
