Hi, Can we connect total of 3 Webex Room Navigator: One table for control and 2 Wall Mounted for Room booking (The meeting room has 2 entrances) to one Codec EQ? The navigators will be connected through a switch. Thank you,
Hello,I have a Codec EQ with a Room Vision PTZ connected via Ethernet directly to the codec. We have had multiple instances of users reporting that the camera will not output video to the codec. The camera will physically move when a preset is select...
Webex Console as an Operator / we have 2 8851 with multiple Side Cars what's the solution moving them to Webex App we are in a hybrid solution Using the Webex APP in Control under users for Calling selecting registered to CUCMPlan next year moving 1...
Bonjour,J’ai un Cisco Webex Room 55. Je l’ai réinitialisé car il affichait « Impossible d’établir la connexion aux services Cisco Webex ».Depuis la réinitialisation :· Je me connecte au Wi-Fi (maison, pas de proxy).· Je choisis « Cisco Webex » comme...
Hello everyone,Does anyone know the correct Cisco support contract part numbers for Smart Net Total Care 8x5x Next Business Day for the following microphones?CS-MIC-ARRAY-TCS-MIC-ARRAY-T-CWhile searching online, I found the following SKUs:CON-SNT-CSM...
Hello!I am interested in simplifying my audio set up for one of the large meeting rooms for my organization. We currently have some shure wireless microphones that we use in addition to various ceiling microphones. Is there any way to directly integr...
Hi , Good Day. Is there any configuration backup on the Control hub. Something like you can revert the change on the dial-plan , user/agent information , hunt group setting to a previous stage (maybe 2 week ago). This is to avoid there is a misconf...
Hi I have a RMA's unit sent to site, it powers on fine, but is stuck in some form of factory test/diagnostics page.Please see photo attached.I have factory reset the unit, power cycled it multiple times but it still come back to the same page.Has any...
Hi, I'm looking for full network traffic for Miracast WiFi Direct and Wifi Direct over infrastructure - MS MICE.There is lack of information in Cisco documentation:Configure wireless sharing with Miracast® (webex.com)as they seem to mention only 7236...
HiI want to add Cisco IP Phone 8875 in Webex control hub. What are the licenses are required for this? How can I prepare this BoQ?Anyone can help me on this.
Hi All,we recently installed Cisco Room kit EQ codec and Cisco Room Bar (Standalone - BYOD). we also purchased Cisco Active USB-C Cable 9m (USB-C 3.1 Active Optical Cable, 9M length) as it will allow us to remove HDMI cables and chargers while using ...
This has a proposed fix in RoomOS26.4.1.4 and newer. Testing confirmed. Bug ID page doesn't show any known fixed releases.
Is there are reason why the Call Queue removes caller ID information and only displays "[Call Queue Name] - [Caller Phone Number]"? Without Call Queue Caller ID information is displayed on the device "[Caller ID Name] - [Caller Phone Number]", but as...
I have a Cisco Room Kit. It was purchased in 2020, to give you an idea of it's generation.I have a scenario where I'd like to couple it with a PTZ on the other side of the room. The purpose would be so that the main camera (on top of the TV) would lo...
| Subject | Author | Posted |
| 08-21-2026 06:50 AM | ||
| 08-19-2026 12:20 AM | ||
| 08-18-2026 09:22 AM | ||
| 08-16-2026 04:53 PM | ||
| 07-16-2026 08:47 AM |
