Showing results forĀ
Search instead forĀ
Did you mean:Ā
Codec EQ with MTR Not able to do Content Sharing
I have a team eq & unable to do content sharing in a meeting with MTR solution when it is already connected with an HDMI port on the codec local presentations happens
6 Replies 6
lzhu
Is it working when sharing content locally?
If so, the account might be missing the audio video policy. You can check that in Microsoft 365 Admin Centre and see if the correct audio video policy has been assigned to the resource account.
Yes it works Locally, but via the video call we need are unable to press the main page to share it says to connect an HDMI cable
Can you also try starting a Meet Now meeting from the touch panel, and see if you see any errors? Since you can share locally, which indicates the physical connections are correct. I still feel that the Codec EQ in MTR mode is not configured correctly. It might have missed a policy that enables audio/video on the MS Teams side.
Dipak Kadam
Hello Dominic ,
is it working on normal presentation with out any microsoft team calls?
also please check below settings in Codec eq GUI Page.
Setting->Video->Connector 2->PresentationSelection->Autoshare
Setting->Video->Connector 2->PresentationSelection->Visibility->Always
No still its not able to share
directly from the main page it opens from the setting page on the right side
hello Dominic ,
please update codec EQ firmeware.
