Codec Pro software upgrade without subscription
VISITFLORIDA
We have 2 Codec Pros that are registered with our Zoom Conference Room Connector. For whatever reason one came with RoomOS 10.20.1.6 and the other came with RoomOS 10.8.3.1.6. Is there a way to upgrade the OS without a Cisco subscription? These devices aren't exactly cheap and it seems like poor customer service to not provide any support or updates at least until they are up and running properly.
John Steele
Not under normal circumstances.  One option is to work with your Cisco partner to setup a Webex Trial (which is free) and then connect those devices to the trial, upgrade.
