room kit pro
siddhesh gujar
hello everyone ,we are using room kit pro and we are facing below issue, does anybody already face the same issue before just let me know urgently .
TheTechCatalyst
This is likely a firewall issue.  I would review this document in detail:  https://help.webex.com/en-us/article/WBX000028782/Network-Requirements-for-Webex-Services
Also, if you go to Device Settings > Issues and Diagnostics > Webex Connection Details it will show you the specific services that are not connecting which should shorten your search for the issue.
Hope that helps!
TheTechCatalyst
Hope that helps!
