roomos 11
erik.pouplier1
Hello, is it possible to test the roomos 11 version on a single codec (room kit mini for example) without passing all codecs in this new version. Thanks
  • Don't web to the device.  if the device is cloud registered then Go to the device in CH, find All Configurations then look for
    All
  • UserInterface
  • Concept
  • Mode
    Set to Compositor
Response Signature
erik.pouplier1
Thank you for the documentation but when I look at it, I can't find the section corresponding to "userInterface Concept Mode" on the codec's web interface. Is it accessible in cli mode?
    All
  • UserInterface
  • Concept
  • Mode
    Set to Compositor
Response Signature
