View devices in call in Control Hub
chris.barlow1
Hi, is there a way in control Hub to see all room endpoints currently in a call? In other words to replace this functionality from TMS
John Steele
There are analytics for completed meetings/calls but i don't think that helps you.  Because you can pull active status from a device itself, perhaps there is an API that can help.  You can also submit the idea in aha.
https://ciscocollabcustomer.ideas.aha.io/ideas
Eric Ingram
Level 4
Level 4
Have you seen the tool CE-Deploy?  There are always new features that enable us to manage our devices.  There is a pretty cool dashboard function that has "call status" column.
John Steele
