06-05-2021 11:27 AM
Hello, I am having a problem with my Webex Board 70. The system was working properly then it just went into a maintenance mode. Tried restarting it, tried factory reset, and with Cisco's website you have to have a maintenance contract in order to download new software. I'm afraid the answer is going to be it needs to be RMA'd. Any help will be appreciated.
06-12-2021 02:34 PM
2021-06-12T21:18:01.851+00:00 appl[3006]: SoftwareUpgrade I: Server starting. Prefetch bifrost pkg: false 2021-06-12T21:18:01.852+00:00 appl[3006]: SoftwareUpgrade[0]: [3982045200] LFH::LoadsFileHandler() {cI=false,rCT=0,cT=60,a=false,uP=Init,cP=N} 2021-06-12T21:18:01.852+00:00 appl[3006]: SoftwareUpgrade[0]: [3982045200] LFH::LoadsFileHandler() {cI=false,rCT=0,cT=60,a=false,uP=Init,cP=N} <- 2021-06-12T21:18:01.852+00:00 appl[3006]: SoftwareUpgrade I: S/W upgrade handler initialized 2021-06-12T21:18:01.852+00:00 appl[3006]: SoftwareUpgrade I: Delayed metric initialized/ 2021-06-12T21:18:18.786+00:00 video[3592]: Video process starting 2021-06-12T21:18:18.796+00:00 video[3592]: memorylock: run mlockall() for video process 2021-06-12T21:18:19.107+00:00 video[3592]: SSDEMO_CMD_OPEN: -65528 2021-06-12T21:18:19.107+00:00 video[3592]: Failed to read mic 2021-06-12T21:18:19.110+00:00 video[3592]: Starting notify task 2021-06-12T21:18:19.265+00:00 video[3592]: Waiting for SYSTEM_MAIN to initialise shared memory 2021-06-12T21:18:17.896+00:00 video[3588]: task-management already run, stopping now 2021-06-12T21:18:28.304+00:00 eventlog[3927]: memorylock: run mlockall() for main process 2021-06-12T21:18:28.930+00:00 eventlog[3927]: Darling 2021-06-12T21:18:28.930+00:00 eventlog[3927]: Model: Darling Unknown 2021-06-12T21:18:28.930+00:00 eventlog[3927]: Main board: C 2021-06-12T21:18:28.930+00:00 eventlog[3927]: Module partno/sno: 699-82180-1000-400 T.0/0322317079227 2021-06-12T21:18:28.930+00:00 eventlog[3927]: BOM: 0 2021-06-12T21:18:28.944+00:00 eventlog[3927]: UDI: SPARK-BOARD70 V01 RSU21330198 2021-06-12T21:18:28.944+00:00 eventlog[3927]: Serial number: RSU21330198 2021-06-12T21:18:28.951+00:00 eventlog[3927]: ce10.4.1.1.85ff0a04877 2021-06-12T21:18:28.951+00:00 eventlog[3927]: SW Release Date: 2021-05-12 2021-06-12T21:18:28.951+00:00 eventlog[3927]: Product ID: Cisco Webex Board 70 2021-06-12T21:18:29.211+00:00 eventlog[3927]: Starting notify task 2021-06-12T21:18:29.244+00:00 eventlog[3927]: Creating and initialising shared memory 2021-06-12T21:18:29.244+00:00 eventlog[3927]: Shared memory configuration: base: 0x0xa0000000, total size: 1048576 2021-06-12T21:18:29.244+00:00 eventlog[3927]: Shared memory buffer pool: base: 0x0xa1000000, total size: 74750464 2021-06-12T21:18:29.245+00:00 eventlog[3927]: Shared memory configuration: used size: 75860 2021-06-12T21:18:29.245+00:00 eventlog[3927]: Shared memory buffer pool: used size: 70708672 2021-06-12T21:18:29.245+00:00 eventlog[3927]: Signal that shared memory has been initialised 2021-06-12T21:18:29.245+00:00 eventlog[3927]: Shared memory initialisation done 2021-06-12T21:18:29.276+00:00 video[3592]: Shared memory initialisation done 2021-06-12T21:18:29.309+00:00 video[3592]: VidSrcCtrl Camera 0: Device -1 2021-06-12T21:18:29.309+00:00 video[3592]: VidSrcCtrl Camera 0: Pixelformat ABGR32 2021-06-12T21:18:29.309+00:00 video[3592]: VidSrcCtrl HDMI RX 1: Device 0 2021-06-12T21:18:29.310+00:00 video[3592]: VidSrcCtrl HDMI RX 1: Pixelformat ABGR32 2021-06-12T21:18:29.310+00:00 video[3592]: HdmiStreams-1 I: Opening V4L2 device /dev/video0 2021-06-12T21:18:29.310+00:00 video[3592]: HdmiStreams-1 I: reset mPool 2021-06-12T21:18:29.313+00:00 video[3592]: FSM [FsmVidDec]: setting message timeout to 0ms 2021-06-12T21:18:29.313+00:00 video[3592]: FSM [FsmVidEnc]: setting message timeout to 0ms 2021-06-12T21:18:29.313+00:00 video[3592]: FSM [FsmInference]: setting message timeout to 0ms 2021-06-12T21:18:29.313+00:00 video[3592]: FSM [FsmComRouter]: setting message timeout to 0ms 2021-06-12T21:18:29.313+00:00 video[3592]: FSM [FsmMain]: setting message timeout to 1000ms 2021-06-12T21:18:29.315+00:00 video[3592]: FeedbackReqCtrl: using LTRF 2021-06-12T21:18:29.315+00:00 video[3592]: CameraDecoder: errorfilter|h264seictrl|h264checksumctrl|metadatactrl|decstatectrl|feedbackreqctrl|maridecctrl|h264sanitizer|ttvdec_h264_omx 2021-06-12T21:18:29.315+00:00 video[3592]: Starting videoproducer service 2021-06-12T21:18:29.354+00:00 appl[3006]: SoftwareUpgrade[0]: [3964281424] SWUH::setSystemState() {s=Init,p=Init,cp=N,tT=0,LFH=(cI=false,rCT=0,cT=60,a=false,uP=Init,cP=N)} state=0 2021-06-12T21:18:29.354+00:00 appl[3006]: SoftwareUpgrade I: Pausing 2021-06-12T21:18:29.354+00:00 appl[3006]: SoftwareUpgrade[0]: [3964281424] LFH::pauseDownloads() {cI=false,rCT=0,cT=60,a=false,uP=Init,cP=N} 2021-06-12T21:18:29.354+00:00 appl[3006]: SoftwareUpgrade I: LoadsFileHandler: Pausing activity 2021-06-12T21:18:29.354+00:00 appl[3006]: SoftwareUpgrade I: Farmer: Paused 2021-06-12T21:18:29.354+00:00 appl[3006]: SoftwareUpgrade[0]: [3964281424] LFH::pauseDownloads() {cI=false,rCT=0,cT=60,a=false,uP=Init,cP=N} <- All activity paused 2021-06-12T21:18:29.354+00:00 appl[3006]: SoftwareUpgrade I: Delayed metric paused/ 2021-06-12T21:18:29.354+00:00 appl[3006]: SoftwareUpgrade[0]: [3964281424] SWUH::setSystemState() {s=Init,p=Init,cp=N,tT=0,LFH=(cI=false,rCT=0,cT=60,a=false,uP=Init,cP=N)} <- 2021-06-12T21:18:29.354+00:00 appl[3006]: SoftwareUpgrade I: set_systemid('<removed for privacy>') 2021-06-12T21:18:29.355+00:00 appl[3927]: RoomControl I: No active configuration 2021-06-12T21:18:29.408+00:00 appl[3927]: CECCTRL I: FSM Started 2021-06-12T21:18:29.410+00:00 appl[3927]: ButtonListener I: button_task key_path '/dev/input/buttons' camera_lid_path '' 2021-06-12T21:18:29.414+00:00 video[3592]: UDPStream: error setting up listen socket (16), errno: Cannot assign requested address 2021-06-12T21:18:29.298+00:00 video[3592]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root' 2021-06-12T21:18:29.348+00:00 video[3592]: NvOpenMaxDecoder:: failed to connect PowerManager!NvOpenMaxDecoder:: failed to connect PowerManager!NvOpenMaxDecoder:: failed to connect PowerManager!NvOpenMaxDecoder:: failed to connect PowerManager!NvOpenMaxDecoder:: failed to connect PowerManager!NvOpenMaxDecoder:: failed to connect PowerManager!NvOpenMaxDecoder:: failed to connect PowerManager!NvOpenMaxDecoder:: failed to connect PowerManager!NvOpenMaxDecoder:: failed to connect PowerManager!NvOpenMaxDecoder:: failed to connect PowerManager!NvOpenMaxDecoder:: failed to connect PowerManager!NvOpenMaxDecoder:: failed to connect PowerManager!NvOpenMaxDecoder:: failed to connect PowerManager!NvOpenMaxDecoder:: failed to connect PowerManager!NvOpenMaxDecoder:: failed to connect PowerManager!NvMMLiteOpen : Block : BlockType = 261 2021-06-12T21:18:29.372+00:00 video[3592]: NvMMLiteBlockCreate : Block : BlockType = 261 2021-06-12T21:18:29.378+00:00 video[3592]: NvMMLiteTVMRDecSetAttribute:: Error status reporting set to 1 2021-06-12T21:18:29.650+00:00 eventlog[3927]: FSM [FsmAudio]: setting message timeout to 5000ms 2021-06-12T21:18:29.650+00:00 eventlog[3927]: FSM [FsmMedia]: setting message timeout to 5000ms 2021-06-12T21:18:29.650+00:00 eventlog[3927]: FSM [FsmMain]: setting message timeout to 5000ms 2021-06-12T21:18:29.650+00:00 eventlog[3927]: FSM [FsmProv]: setting message timeout to 5000ms 2021-06-12T21:18:29.650+00:00 eventlog[3927]: FSM [FsmParagent]: setting message timeout to 5000ms 2021-06-12T21:18:29.650+00:00 eventlog[3927]: FSM [FsmAudioFiles]: setting message timeout to 5000ms 2021-06-12T21:18:29.651+00:00 eventlog[3927]: FSM [FsmXapi]: setting message timeout to 5000ms 2021-06-12T21:18:29.651+00:00 eventlog[3927]: FSM [FsmAudSpeakerTrack]: setting message timeout to 5000ms 2021-06-12T21:18:29.651+00:00 eventlog[3927]: FSM [FsmAudioCtrl]: setting message timeout to 5000ms 2021-06-12T21:18:29.653+00:00 eventlog[3927]: Audioio_darling_fpga: using FPGA revision: 21 2021-06-12T21:18:29.659+00:00 eventlog[3927]: alsastream loopback0_in: channels 2 rate 48000 bufsize 2400 periodsize 480 2021-06-12T21:18:29.659+00:00 eventlog[3927]: alsastream loopback0_in: Successfully opened capture pcm hw:Loopback,0,0 in nonblocking mode, framesize 480 2021-06-12T21:18:29.659+00:00 eventlog[3927]: alsastream loopback1_in: channels 2 rate 48000 bufsize 2400 periodsize 480 2021-06-12T21:18:29.659+00:00 eventlog[3927]: alsastream loopback1_in: Successfully opened capture pcm hw:Loopback,0,1 in nonblocking mode, framesize 480 2021-06-12T21:18:29.660+00:00 eventlog[3927]: alsastream loopback2_in: channels 2 rate 48000 bufsize 2400 periodsize 480 2021-06-12T21:18:29.660+00:00 eventlog[3927]: alsastream loopback2_in: Successfully opened capture pcm hw:Loopback,0,2 in nonblocking mode, framesize 480 2021-06-12T21:18:29.660+00:00 eventlog[3927]: alsastream loopback3_in: channels 2 rate 48000 bufsize 2400 periodsize 480 2021-06-12T21:18:29.660+00:00 eventlog[3927]: alsastream loopback3_in: Successfully opened capture pcm hw:Loopback,0,3 in nonblocking mode, framesize 480 2021-06-12T21:18:29.660+00:00 eventlog[3927]: alsastream loopback4_in: channels 2 rate 48000 bufsize 2400 periodsize 480 2021-06-12T21:18:29.661+00:00 eventlog[3927]: alsastream loopback4_in: Successfully opened capture pcm hw:Loopback,0,4 in nonblocking mode, framesize 480 2021-06-12T21:18:29.661+00:00 eventlog[3927]: alsastream loopback5_in: channels 2 rate 48000 bufsize 2400 periodsize 480 2021-06-12T21:18:29.661+00:00 eventlog[3927]: alsastream loopback5_in: Successfully opened capture pcm hw:Loopback,0,5 in nonblocking mode, framesize 480 2021-06-12T21:18:29.661+00:00 eventlog[3927]: alsastream loopback6_in: channels 2 rate 48000 bufsize 2400 periodsize 480 2021-06-12T21:18:29.661+00:00 eventlog[3927]: alsastream loopback6_in: Successfully opened capture pcm hw:Loopback,0,6 in nonblocking mode, framesize 480 2021-06-12T21:18:29.662+00:00 eventlog[3927]: alsastream loopback7_in: channels 2 rate 48000 bufsize 2400 periodsize 480 2021-06-12T21:18:29.662+00:00 eventlog[3927]: alsastream loopback7_in: Successfully opened capture pcm hw:Loopback,0,7 in nonblocking mode, framesize 480 2021-06-12T21:18:29.662+00:00 eventlog[3927]: alsastream loopback_out: channels 1 rate 48000 bufsize 2400 periodsize 480 2021-06-12T21:18:29.662+00:00 eventlog[3927]: alsastream loopback_out: Successfully opened playback pcm hw:Loopback,0,0 in nonblocking mode, framesize 480 2021-06-12T21:18:29.663+00:00 eventlog[3927]: alsa_event_listener: Listening on hw:Loopback 2021-06-12T21:18:30.862+00:00 eventlog[3927]: Setting FIPS mode to false 2021-06-12T21:18:30.864+00:00 eventlog[3927]: platformd: error sending (101): Network is unreachable 2021-06-12T21:18:30.906+00:00 appl[3927]: Paragent I: MSCtrlSubscriber sending MS_Init_Req ip= 2021-06-12T21:18:30.909+00:00 video[3592]: VideoLC I: VLC_initAlloc_Req: Platform: Sunrise 2021-06-12T21:18:30.909+00:00 video[3592]: VideoLC I: Initialize 1 VIDSRCCTRL_FSMs and 1 DISPCTRL_FSMs 2021-06-12T21:18:30.914+00:00 video[3592]: VidSrcCtrl HDMI RX 1: Source Not Connected 2021-06-12T21:18:30.916+00:00 video[3592]: VideoLC[0]: Received VIDSRCCTRL_Init_Cnf from ind 0, status: 0 2021-06-12T21:18:30.916+00:00 video[3592]: VideoLC I: Received VIDSRCCTRL_SignalSourceEvent from HDMI 2 (fsm-ind 0) in init pending: not connected 2021-06-12T21:18:30.916+00:00 video[3592]: VideoLC I: Received SignalFormatEvent from video link 1 (fsm-ind 0, 0x0@0, unknown type, timings not found) in init pending 2021-06-12T21:18:30.916+00:00 video[3592]: VideoLC I: Received SignalTmdsClockEvent from video link 1 (fsm-ind 0, 0) in init pending 2021-06-12T21:18:30.916+00:00 video[3592]: VideoLC I: Received SignalFormatEvent from video link 1 (fsm-ind 0, 0x0@0, unknown type, timings not found) in init pending 2021-06-12T21:18:30.916+00:00 video[3592]: VideoLC[0]: Received DISPCTRL_Init_Cnf from fsm-ind 0, status: 0 2021-06-12T21:18:30.916+00:00 video[3592]: VLC: init camerea control fsm 0 2021-06-12T21:18:30.916+00:00 video[3592]: CameraControlFsm: Initializing FSM 2021-06-12T21:18:30.916+00:00 video[3592]: VideoLC I: VLC_initPendingInitCnf: vidsrc status=0x00010001, disp status=0x00010001 2021-06-12T21:18:30.916+00:00 video[3592]: VideoLC I: do_ReadySignalDisplayEvent LCD 1 present: true 2021-06-12T21:18:30.917+00:00 appl[3927]: HttpClient I: ce-http::Engine::setProxyConfig: proxy mode=Off, url='' 2021-06-12T21:18:30.917+00:00 video[3592]: VideoLC[0]: VLC_commonSubscribeEvent_Req from PARAGENT-0 2021-06-12T21:18:30.917+00:00 video[3592]: VideoLC I: Set RGB quantization range for video source HDMI 2 to 0 2021-06-12T21:18:30.917+00:00 video[3592]: VideoLC[0]: RGB quantization range from video source HDMI 2 confirmed 0 2021-06-12T21:18:30.917+00:00 video[3592]: VideoLC I: do_ReadyInputPreferredResolutionReq HDMI 2 1920x1080@60 2021-06-12T21:18:30.917+00:00 appl[3927]: CECCTRL I: FSM Init 2021-06-12T21:18:30.963+00:00 appl[3927]: CECCTRL I: /dev/cec0 (i 2) Got logical address: 255 2021-06-12T21:18:30.966+00:00 video[3592]: VideoLC I: VIDEOLC_doReadyConfigureInputHdmiCecModeReq:port 2 2021-06-12T21:18:30.966+00:00 video[3592]: VideoLC I: Configure LCD 1 output to 3840x2160@60Hz lvds timing 2021-06-12T21:18:30.968+00:00 video[3592]: androidSetDisplay,65(0): Activated config 0 for w 3840 h 2160 fps 60.0 2021-06-12T21:18:30.978+00:00 appl[3927]: CECCTRL I: /dev/cec0 (i 2) Enabled = true 2021-06-12T21:18:30.985+00:00 video[3592]: VideoLC I: Overscan request for LCD 1 to h:0 v:0 2021-06-12T21:18:30.985+00:00 video[3592]: VideoLC I: VLC_readyQueryInputHwCookie_Req: 1 2021-06-12T21:18:30.985+00:00 video[3592]: VideoLC I: VLC_readyQueryInputHwCookie_Req: 2 2021-06-12T21:18:30.986+00:00 video[3592]: VideoLC I: VLC_readyQueryOutputHwCookie_Req: 1 2021-06-12T21:18:30.986+00:00 video[3592]: VideoLC[0]: Configuration of output LCD 1 to 3840x2160@60Hz timing confirmed 2021-06-12T21:18:30.986+00:00 video[3592]: VideoLC[0]: Overscan confirmed for LCD 1, set to h:0 v:0 2021-06-12T21:18:30.987+00:00 appl[3927]: SipSubscriber I: Not sending SIP stack config because network is down. 2021-06-12T21:18:31.198+00:00 appl[3716]: Last message 'SipSubscriber I: Not' repeated 1 times, suppressed by syslog-ng 2021-06-12T21:18:31.198+00:00 appl[3927]: CAMERA I: serial number configuration is ok 2021-06-12T21:18:31.198+00:00 appl[3927]: FeatureController I: FeatureController Start FeatureController 2021-06-12T21:18:31.198+00:00 appl[3927]: APPL_Swarm I: Swarm: Enabled: false 2021-06-12T21:18:31.199+00:00 appl[3927]: APPL_Swarm I: Swarm: Leader: true 2021-06-12T21:18:31.199+00:00 appl[3927]: APPL_LocalItems I: MicMuteLedControllerImpl::directChannelExistsChanged : directChannelExists: false 2021-06-12T21:18:31.200+00:00 appl[3927]: APPL_Media I: CapabilityControllerImpl::setCapset() reductionLevel = 0, waitForDuoGate = false 2021-06-12T21:18:31.216+00:00 appl[3927]: VoiceControl I: Updated ttparams: is_provider_avs = false, assistant_opted_in = false 2021-06-12T21:18:31.216+00:00 appl[3927]: VoiceControl W: No assistant was running 2021-06-12T21:18:31.236+00:00 appl[3927]: CECCTRL I: /dev/cec0 (i 2) Got logical address: 0 2021-06-12T21:18:31.263+00:00 appl[3927]: GRPC I: grpc log verbosity ERROR no tracers 2021-06-12T21:18:31.288+00:00 appl[3927]: CeMetrics I: Metrics rpc service started 2021-06-12T21:18:31.288+00:00 appl[3927]: PeripheralServiceRpc I: PeripheralService rpc service started 2021-06-12T21:18:31.292+00:00 appl[3927]: APPL_Presentation[0]: PresentationControllerImpl::setTokenBasedView [CMD] minimize=false 2021-06-12T21:18:31.292+00:00 appl[3927]: byod I: Restarting byod API server due to config change. max_clients=30 call_control=false share_to_client=false share_from_client=true temporarily_deactivated=false 2021-06-12T21:18:31.293+00:00 appl[3927]: byod I: Restarting byod API server due to config change. max_clients=30 call_control=false share_to_client=false share_from_client=true temporarily_deactivated=true 2021-06-12T21:18:31.316+00:00 appl[3927]: msctrl ERROR: UsbCamOut::outputChanged: mixer does not exist! 2021-06-12T21:18:31.316+00:00 appl[3927]: APPL_ConfCtrl I: LocalParticipantImpl::doSetup 2021-06-12T21:18:31.316+00:00 appl[3927]: APPL_ConfCtrl I: LocalParticipantImpl::setupVideoGates creating 2 localVideoInputGates 2021-06-12T21:18:31.316+00:00 appl[3927]: APPL_ConfCtrl I: LocalParticipantImpl::setupVideoGates creating 1 localVideoOutputGates 2021-06-12T21:18:31.325+00:00 appl[3927]: Wx2 I: void ConferenceControl::{anonymous}::Impl::start_or_stop_controller(ConferenceControl::{anonymous}::ControllerTransitionReason) wx2_mode_enabled=false, cloud_aware_enabled=false, account_complete=false, network_ready=false, interface=LAN, system_ready_=false, software_supported=true, reason=initialized, start_or_stop_count=0, prior_starts=0, prior_stops=0 2021-06-12T21:18:31.325+00:00 appl[3927]: Wx2 I: bool ConferenceControl::{anonymous}::Impl::should_provision_shared_account() PersonalMode=false,personal_account_complete=false, !shared_account_complete=true, !shared_account_provisioner_->is_running()=true 2021-06-12T21:18:31.325+00:00 appl[3927]: Wx2 I: CallHistoryClient: Stopping 2021-06-12T21:18:31.325+00:00 appl[3927]: MainEvents I: MainEventLogProducerImpl created 2021-06-12T21:18:31.335+00:00 appl[3927]: APPL_ConfCtrl ERROR: Unable to enable BYOD Mode. A valid IPv4 address is required. 2021-06-12T21:18:31.335+00:00 appl[3927]: CAMERA I: CameraFacade::Init_doCAMInitReq 2021-06-12T21:18:31.335+00:00 appl[3927]: DarlingCameraConnector I: Trying to connect to camera... 2021-06-12T21:18:31.336+00:00 eventlog[3927]: doric: connectImpl: connect() to '169.254.1.30:13496' failed: Network is unreachable<trunc> 2021-06-12T21:18:31.336+00:00 eventlog[3927]: Transport error 2021-06-12T21:18:31.336+00:00 appl[3927]: DarlingCameraConnector I: Connection error 2021-06-12T21:18:31.336+00:00 appl[3927]: msctrl W: void msctrl::VideoMixer::Impl::configVC() Attempt to reconfigure mixer with exact same settings as last time mixerId=[id=15] state=allocMedia mediaId=15 std=0, height=-1 width=-1 2021-06-12T21:18:31.429+00:00 appl[3927]: APPL_Media I: CapabilityControllerImpl::setCapset() reductionLevel = 0, waitForDuoGate = false 2021-06-12T21:18:31.438+00:00 appl[3927]: DATACTRL I: FECCCAPSREQ(): received global controller fecc capabilities 2021-06-12T21:18:31.462+00:00 video[3592]: VideoLC I: PowerManagement, request standby state off 2021-06-12T21:18:31.462+00:00 video[3592]: VideoLC I: PowerManagement confirm, backlight on 2021-06-12T21:18:31.462+00:00 appl[3927]: MainEvents I: LocalParticipantCreated(p=1) 2021-06-12T21:18:31.462+00:00 appl[3927]: Wx2 I: void ConferenceControl::{anonymous}::Impl::start_or_stop_controller(ConferenceControl::{anonymous}::ControllerTransitionReason) wx2_mode_enabled=false, cloud_aware_enabled=false, account_complete=false, network_ready=false, interface=LAN, system_ready_=true, software_supported=true, reason=local-participant-created, start_or_stop_count=1, prior_starts=0, prior_stops=0 2021-06-12T21:18:31.463+00:00 appl[3927]: Wx2 I: bool ConferenceControl::{anonymous}::Impl::should_provision_shared_account() PersonalMode=false,personal_account_complete=false, !shared_account_complete=true, !shared_account_provisioner_->is_running()=true 2021-06-12T21:18:31.464+00:00 appl[3927]: APPL_Addons I: LayoutInfoForTranscodedImpl::LayoutInfoForTranscodedImpl Initialized with waiting time=0ms 2021-06-12T21:18:31.464+00:00 appl[3927]: APPL_Addons I: SelfviewControlImpl::SelfviewControlImpl application created 2021-06-12T21:18:31.470+00:00 appl[3927]: AutoPairingManager I: NOD not Started 2021-06-12T21:18:31.470+00:00 appl[3927]: FacerecMediaControl I: FacerecMediaControl supportType 2 is_board true 2021-06-12T21:18:31.471+00:00 appl[3927]: APPL_Addons I: CurrentlySpeaking::CurrentlySpeaking application created 2021-06-12T21:18:31.471+00:00 appl[3927]: APPL_Addons I: MicMuteCtrl::MicMuteCtrl application created 2021-06-12T21:18:31.471+00:00 appl[3927]: MainEvents I: Mic Unmuted 2021-06-12T21:18:31.472+00:00 appl[3927]: APPL_Addons I: MusicMode : deactivate 2021-06-12T21:18:31.474+00:00 appl[3927]: APPL_Addons I: denoise: not active 2021-06-12T21:18:31.476+00:00 appl[3927]: MainEvents I: LocalLayoutToBeSet outputNo=1 resolutionChangedSameAspect=false 2021-06-12T21:18:31.476+00:00 appl[3927]: MainEvents I: LayoutUpdated(p=1) output=1 og=107 c=1, frame[GUI] Gui p=1 src=1 ig=-1 csi=0xffffffff type=- avatar=0 reso=-1/-1 crop=0/0/1000/1000 x=0 y=0 w=10000 h=10000 l=0 b=0 m=0 Letterbox fcref=0 wbSession=0 wbUrl= pip=0 2021-06-12T21:18:31.481+00:00 eventlog[3927]: Audioio_darling_fpga: audio_input thread starting 2021-06-12T21:18:31.482+00:00 appl[3006]: SoftwareUpgrade[0]: [3964281424] SWUH::onMainReady() {s=Init,p=Init,cp=N,tT=0,LFH=(cI=false,rCT=0,cT=60,a=false,uP=Init,cP=N)} 2021-06-12T21:18:31.482+00:00 appl[3006]: SoftwareUpgrade[0]: [3964281424] SWUH::evaluateLastUpgrade() {s=Init,p=Init,cp=N,tT=0,LFH=(cI=false,rCT=0,cT=60,a=false,uP=Init,cP=N)} 2021-06-12T21:18:31.483+00:00 eventlog[3927]: Audioio_darling_fpga: ftdi_new failed 2021-06-12T21:18:31.483+00:00 eventlog[3927]: Received signal SIGABRT (6) in thread 0xe5397ba0, TID 4220 (AudioIO) 2021-06-12T21:18:31.483+00:00 eventlog[3927]: Registers: 2021-06-12T21:18:31.483+00:00 eventlog[3927]: R0: 00000000 R1: e53971a0 R2: 00000000 R3: 00000008 2021-06-12T21:18:31.483+00:00 eventlog[3927]: R4: 00000006 R5: 7fffffff R6: e816a8f8 R7: 000000af 2021-06-12T21:18:31.483+00:00 eventlog[3927]: R8: 17642dd0 R9: 00000002 R10: 11019480 FP: e5393000 2021-06-12T21:18:31.483+00:00 eventlog[3927]: PC: e691dcbc IP: 00000000 SP: e53971a0 LR: e53971a0 2021-06-12T21:18:31.483+00:00 eventlog[3927]: ERR: 00000000 CPSR: 00000010 FAULT: 00000000 TRAP: 00000000 2021-06-12T21:18:31.483+00:00 eventlog[3927]: OLDMSK: 00000000 2021-06-12T21:18:31.483+00:00 eventlog[3927]: Task Type Pri TID STACK PTR %CPU %PROC TIME+ STACK AFFINITY 2021-06-12T21:18:31.483+00:00 eventlog[3927]: ----------------------------------------------------------------------------------------- 2021-06-12T21:18:31.483+00:00 appl[3006]: SoftwareUpgrade[0]: [] ImageCollector::detect_mode (None) 2021-06-12T21:18:31.483+00:00 eventlog[3927]: CustomIconQueue OT 0 3989 0xe65da000 0.0 0.0 0:00.000 13472/32768 0-3 2021-06-12T21:18:31.483+00:00 eventlog[3927]: applstart OT 0 3927 0x00000000 3.6 68.0 0:02.134 0/0 0-3 2021-06-12T21:18:31.483+00:00 eventlog[3927]: jebus_mainloop OT 0 4016 0xe6574000 0.0 0.1 0:00.004 15576/409600 0-3 2021-06-12T21:18:31.483+00:00 eventlog[3927]: notify RR 25 4017 0xe6535000 0.0 0.1 0:00.002 15188/32768 0-3 2021-06-12T21:18:31.483+00:00 eventlog[3927]: shmemdev RR 25 4023 0xe652b000 0.0 0.0 0:00.001 13816/32768 0-3 2021-06-12T21:18:31.484+00:00 eventlog[3927]: FsmParagent OT 0 4025 0xe5e80000 0.1 2.0 0:00.062 32520/524288 0-3 2021-06-12T21:18:31.484+00:00 eventlog[3927]: FsmMain OT 0 4024 0xe6080000 0.7 13.8 0:00.434 43512/524288 0-3 2021-06-12T21:18:31.484+00:00 eventlog[3927]: FsmXapi OT 0 4028 0xe6509000 0.4 8.3 0:00.259 35092/131072 0-3 2021-06-12T21:18:31.485+00:00 eventlog[3927]: FsmProv OT 0 4027 0xe5c80000 0.0 0.0 0:00.001 15980/524288 0-3 2021-06-12T21:18:31.485+00:00 eventlog[3927]: FsmAudio RR 28 4030 0xe605e000 0.3 5.3 0:00.167 25780/131072 2-3 2021-06-12T21:18:31.485+00:00 eventlog[3927]: FsmMedia RR 20 4029 0xe5a60000 0.0 0.1 0:00.002 15980/655360 0-3 2021-06-12T21:18:31.485+00:00 eventlog[3927]: FsmAudioFiles RR 25 4031 0xe604c000 0.0 0.0 0:00.000 15980/65536 0-3 2021-06-12T21:18:31.486+00:00 eventlog[3927]: FsmAudSpeakerTrack OT 0 4032 0xe602a000 0.0 0.0 0:00.000 15980/131072 0-3 2021-06-12T21:18:31.486+00:00 eventlog[3927]: FsmAudioCtrl OT 0 4033 0xe6008000 0.0 0.0 0:00.000 15980/131072 0-3 2021-06-12T21:18:31.486+00:00 appl[3006]: SoftwareUpgrade I: === ImageCollector updated === 2021-06-12T21:18:31.486+00:00 appl[3006]: SoftwareUpgrade I: activeSource='/mnt/base/active/current.loads' 2021-06-12T21:18:31.486+00:00 appl[3006]: SoftwareUpgrade I: s53200 (<-- that's me!) @ ce10.4.1.1 85ff0a04877 2021-05-12 2021-06-12T21:18:31.486+00:00 eventlog[3927]: jpegoutlib OT 0 4057 0xe5e6c000 0.0 0.0 0:00.000 13276/32768 0-3 2021-06-12T21:18:31.486+00:00 eventlog[3927]: jpegoutlib OT 0 4056 0xe5e76000 0.0 0.0 0:00.000 13276/32768 0-3 2021-06-12T21:18:31.486+00:00 appl[3006]: SoftwareUpgrade I: url: https://binaries.webex.com/collaboration-endpoint-ce-production-stable/20210519105032/sunrise.pkg 2021-06-12T21:18:31.486+00:00 appl[3006]: SoftwareUpgrade I: package: sunrise.pkg 2021-06-12T21:18:31.486+00:00 appl[3006]: SoftwareUpgrade I: targets: 2021-06-12T21:18:31.486+00:00 appl[3006]: SoftwareUpgrade I: checksum: 5f433affaaa0e7b1f150dd9e8139252204babecf84e6bd262f895dbbebcf6ed61ea2c6b6433abef5d077a3838081500ff54b520de2380dd20426e85e0719c56c 2021-06-12T21:18:31.486+00:00 appl[3006]: SoftwareUpgrade I: Idefix @ ce10.4.1.1 85ff0a04877 2021-05-12 2021-06-12T21:18:31.486+00:00 appl[3006]: SoftwareUpgrade I: url: /mnt/base/active/peripherals/idefix.pkg (exists) 2021-06-12T21:18:31.486+00:00 appl[3006]: SoftwareUpgrade I: package: idefix.pkg 2021-06-12T21:18:31.486+00:00 appl[3006]: SoftwareUpgrade I: targets: 102300-3,102310-0,102310-1,101282-0 2021-06-12T21:18:31.486+00:00 appl[3006]: SoftwareUpgrade I: checksum: 0241d658a06b256573fafb1708c11c3da3f82e23b4a02717688a47ca584329c7e06b1480d1da70e5cab807115ef1ab4db7ed093bca413bf2cb55bf7bf6a7c662 2021-06-12T21:18:31.486+00:00 appl[3006]: SoftwareUpgrade[0]: [] ImageCollector::detect_mode (Current) <- 2021-06-12T21:18:31.486+00:00 eventlog[3927]: HttpFeedbackInvoker OT 0 4058 0xe5e20000 0.0 0.0 0:00.000 13696/32768 0-3 2021-06-12T21:18:31.486+00:00 eventlog[3927]: XapiHTTPInvoker OT 0 4059 0xe5e0e000 0.0 0.0 0:00.000 13528/65536 0-3 2021-06-12T21:18:31.486+00:00 eventlog[3927]: Roomcontrol invoker OT 0 4060 0xe5e04000 0.0 0.0 0:00.000 13276/32768 0-3 2021-06-12T21:18:31.486+00:00 eventlog[3927]: audioDiagnostics OT 0 4065 0xe5a08000 0.0 0.0 0:00.000 13436/81920 2-3 2021-06-12T21:18:31.486+00:00 eventlog[3927]: Socket OT 0 4070 0xe5464000 0.0 0.0 0:00.000 13800/65536 0-3 2021-06-12T21:18:31.486+00:00 appl[3006]: SoftwareUpgrade I: Farmer: (Re-/)offering images to all peripherals... 2021-06-12T21:18:31.486+00:00 appl[3006]: SoftwareUpgrade[0]: [3964281424] SWUH::evaluateLastUpgrade() {s=Init,p=HasL,cp=N,tT=0,LFH=(cI=false,rCT=0,cT=60,a=false,uP=HasL,cP=N)} <- 2021-06-12T21:18:31.486+00:00 appl[3006]: SoftwareUpgrade I: Sending 2 queued metrics 2021-06-12T21:18:31.486+00:00 eventlog[3927]: CurlEngine OT 0 4068 0xe5476000 0.0 0.0 0:00.000 14252/262144 0-3 2021-06-12T21:18:31.487+00:00 appl[3006]: SoftwareUpgrade[0]: [3964281424] SWUH::onMainReady() {s=Init,p=HasL,cp=N,tT=0,LFH=(cI=false,rCT=0,cT=60,a=false,uP=HasL,cP=N)} <- 2021-06-12T21:18:31.487+00:00 appl[3006]: SoftwareUpgrade[0]: [3964281424] SWUH::setSystemState() {s=Init,p=HasL,cp=N,tT=0,LFH=(cI=false,rCT=0,cT=60,a=false,uP=HasL,cP=N)} state=1 2021-06-12T21:18:31.487+00:00 appl[3006]: SoftwareUpgrade I: Resuming 2021-06-12T21:18:31.487+00:00 appl[3006]: SoftwareUpgrade[0]: [3964281424] LFH::resumeDownloads() {cI=false,rCT=0,cT=60,a=false,uP=HasL,cP=N} 2021-06-12T21:18:31.487+00:00 appl[3006]: SoftwareUpgrade I: LoadsFileHandler: Resuming activity in state N 2021-06-12T21:18:31.487+00:00 appl[3006]: SoftwareUpgrade I: Farmer: Resumed 2021-06-12T21:18:31.487+00:00 eventlog[3927]: CECCTRL OT 0 4071 0xe545a000 0.0 0.0 0:00.000 13696/32768 0-3 2021-06-12T21:18:31.487+00:00 appl[3006]: SoftwareUpgrade[0]: [3964281424] LFH::resumeDownloads() {cI=false,rCT=0,cT=60,a=false,uP=HasL,cP=N} <- All activity resumed 2021-06-12T21:18:31.487+00:00 eventlog[3927]: usbgadget-monitor OT 0 4067 0xe54b8000 0.0 0.0 0:00.001 21928/81920 0-3 2021-06-12T21:18:31.487+00:00 appl[3006]: SoftwareUpgrade[0]: [3964281424] SWUH::setSystemState() {s=Rdy,p=HasL,cp=N,tT=0,LFH=(cI=false,rCT=0,cT=60,a=false,uP=HasL,cP=N)} <- 2021-06-12T21:18:31.487+00:00 appl[3006]: SoftwareUpgrade[0]: [3964281424] SWUH::setSystemState() {s=Rdy,p=HasL,cp=N,tT=0,LFH=(cI=false,rCT=0,cT=60,a=false,uP=HasL,cP=N)} state=1 2021-06-12T21:18:31.487+00:00 appl[3006]: SoftwareUpgrade I: Resuming 2021-06-12T21:18:31.487+00:00 appl[3006]: SoftwareUpgrade[0]: [3964281424] LFH::resumeDownloads() {cI=false,rCT=0,cT=60,a=false,uP=HasL,cP=N} 2021-06-12T21:18:31.487+00:00 appl[3006]: SoftwareUpgrade I: LoadsFileHandler: Resuming activity in state N 2021-06-12T21:18:31.487+00:00 appl[3006]: SoftwareUpgrade I: Farmer: Resumed 2021-06-12T21:18:31.487+00:00 appl[3006]: SoftwareUpgrade[0]: [3964281424] LFH::resumeDownloads() {cI=false,rCT=0,cT=60,a=false,uP=HasL,cP=N} <- All activity resumed 2021-06-12T21:18:31.487+00:00 eventlog[3927]: CECInvoker OT 0 4073 0xe5446000 0.1 1.2 0:00.037 16076/32768 0-3 2021-06-12T21:18:31.487+00:00 appl[3006]: SoftwareUpgrade[0]: [3964281424] SWUH::setSystemState() {s=Rdy,p=HasL,cp=N,tT=0,LFH=(cI=false,rCT=0,cT=60,a=false,uP=HasL,cP=N)} <- 2021-06-12T21:18:31.487+00:00 eventlog[3927]: CEC-Status OT 0 4072 0xe5450000 0.0 0.0 0:00.000 14792/32768 0-3 2021-06-12T21:18:31.487+00:00 eventlog[3927]: ButtonListener RR 20 4074 0xe8166000 0.0 0.0 0:00.000 14676/16384 0-3 2021-06-12T21:18:31.487+00:00 eventlog[3927]: Websocket server OT 0 4085 0xe5424000 0.0 0.0 0:00.000 15472/131072 0-3 2021-06-12T21:18:31.487+00:00 eventlog[3927]: TimerThread RR 30 4086 0xe541a000 0.0 0.0 0:00.000 13320/32768 0-3 2021-06-12T21:18:31.487+00:00 eventlog[3927]: audioio_darling_fpga_lineout OT 0 4087 0xe6502000 0.0 0.0 0:00.000 13436/20480 3 2021-06-12T21:18:31.487+00:00 eventlog[3927]: alsaevent OT 0 4089 0xe53fe000 0.0 0.0 0:00.000 19736/20480 0-3 2021-06-12T21:18:31.487+00:00 eventlog[3927]: AudioIO RR 29 4220 0xe5393000 0.0 0.2 0:00.005 15676/30720 3 2021-06-12T21:18:31.487+00:00 eventlog[3927]: LedTask OT 0 4221 0xe538d000 0.0 0.0 0:00.000 13752/16384 0-3 2021-06-12T21:18:31.487+00:00 eventlog[3927]: PeripheralPairing OT 0 4222 0xe536b000 0.0 0.1 0:00.003 30120/131072 0-3 2021-06-12T21:18:31.487+00:00 eventlog[3927]: poll_camera OT 0 4223 0xe5365000 0.0 0.0 0:00.000 16244/16384 0-3 2021-06-12T21:18:31.488+00:00 eventlog[3927]: audioctrl OT 0 4261 0xe5343000 0.0 0.3 0:00.009 17048/131072 0-3 2021-06-12T21:18:31.488+00:00 eventlog[3927]: msctrl OT 0 4263 0xe49a7000 0.0 0.3 0:00.008 15492/262144 0-3 2021-06-12T21:18:31.488+00:00 eventlog[3927]: msctrl_cb OT 0 4262 0xe4b7f000 0.0 0.1 0:00.002 14108/262144 0-3 2021-06-12T21:18:31.488+00:00 eventlog[3927]: audgraph-0 RR 28 4279 0xe5321000 0.0 0.0 0:00.000 13436/131072 2-3 2021-06-12T21:18:31.488+00:00 eventlog[3927]: audgraph-1 RR 28 4280 0xe28e0000 0.0 0.0 0:00.000 13436/131072 2-3 2021-06-12T21:18:31.488+00:00 eventlog[3927]: audgraph_worker RR 15 4282 0xe530f000 0.0 0.0 0:00.000 13396/65536 2-3 2021-06-12T21:18:31.488+00:00 eventlog[3927]: VideoStreamService OT 0 4309 0xe5305000 0.0 0.0 0:00.000 13276/32768 0-3 2021-06-12T21:18:31.489+00:00 eventlog[3927]: miracast OT 0 4336 0xe2827000 0.0 0.0 0:00.000 13296/131072 0-3 2021-06-12T21:18:31.489+00:00 eventlog[3927]: byod OT 0 4337 0xe2805000 0.0 0.0 0:00.000 15320/131072 0-3 2021-06-12T21:18:31.489+00:00 eventlog[3927]: wx2-uds-servers OT 0 4345 0xe2448000 0.0 0.0 0:00.000 13296/131072 0-3 2021-06-12T21:18:31.489+00:00 eventlog[3927]: ws-client OT 0 4346 0xe2426000 0.0 0.0 0:00.000 13296/131072 0-3 2021-06-12T21:18:31.489+00:00 eventlog[3927]: onprem-uds-servers OT 0 4350 0xe2022000 0.0 0.0 0:00.000 13296/131072 0-3 2021-06-12T21:18:31.489+00:00 eventlog[3927]: PdfInvoker OT 0 4351 0xe4f0d000 0.0 0.0 0:00.000 13276/32768 0-3 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ------------------------------------------------------------------------------------- 2021-06-12T21:18:31.490+00:00 eventlog[3927]: Cpu: 1.3%proc, 34.0%other, 64.6%idle Total time: 0:03.147 2021-06-12T21:18:31.490+00:00 eventlog[3927]: *** Dumping proc start 2021-06-12T21:18:31.490+00:00 eventlog[3927]: FsmMain currently processing: EPAppl-0 message EPAppl_InvokeStdFunction from ***-3987 (started 27744 us ago) 2021-06-12T21:18:31.490+00:00 eventlog[3927]: FsmParagent last processed: PARAGENT-0 message PARAGENT_InvokeFunction from ***-2051 (started 6481 us ago) 2021-06-12T21:18:31.490+00:00 eventlog[3927]: FsmProv last processed: Prov-0 message Prov_InvokeTTFunction from ***-2054 (started 8296 us ago) 2021-06-12T21:18:31.490+00:00 eventlog[3927]: FsmXapi last processed: XapiFsm-0 message XAPI_Sync from ***-65535 (started 9604 us ago) 2021-06-12T21:18:31.490+00:00 eventlog[3927]: FsmMedia last processed: RtpStack-0 message RTP_Init_Req from MSCtrl-0 (started 502206 us ago) 2021-06-12T21:18:31.490+00:00 eventlog[3927]: FsmAudio last processed: AudGraph-0 message AudGraph_SetupDone from AUDIOCTRL-0 (started 8468 us ago) 2021-06-12T21:18:31.490+00:00 eventlog[3927]: FsmAudioFiles last processed: CECCTRL-0 message ********** from ***-65535 (started 60040490 us ago) 2021-06-12T21:18:31.490+00:00 eventlog[3927]: FsmAudSpeakerTrack last processed: CECCTRL-0 message ********** from ***-65535 (started 60040490 us ago) 2021-06-12T21:18:31.490+00:00 eventlog[3927]: FsmAudioCtrl last processed: AUDIOCTRL-0 message Audgraph_Setup_Done_Confirmed from ***-65535 (started 8394 us ago) 2021-06-12T21:18:31.490+00:00 eventlog[3927]: *** Dumping proc end 2021-06-12T21:18:31.490+00:00 eventlog[3927]: *** product/sunrise/common/target/main/main.c(198): Dumping pools start 2021-06-12T21:18:31.490+00:00 eventlog[3927]: Pool stats 128: 2021-06-12T21:18:31.490+00:00 eventlog[3927]: AUDIOCTRL- 0 -> ***-65535 POOL_msg: count: 60 2021-06-12T21:18:31.490+00:00 eventlog[3927]: VIDMON_FSM- 0 -> ***-65535 POOL_msg: count: 1 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-65535 -> ***-65535 POOL_msg: count: 70 2021-06-12T21:18:31.490+00:00 eventlog[3927]: PARAGENT- 0 -> ***-65535 POOL_msg: count: 16 2021-06-12T21:18:31.490+00:00 eventlog[3927]: VIDEOCTRL- 0 -> ***-65535 POOL_msg: count: 49 2021-06-12T21:18:31.490+00:00 eventlog[3927]: EPAppl- 0 -> ***-65535 POOL_msg: count: 3 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-65535 -> EPAppl- 0 EPAppl_Audgraph_Setup_Done: count: 1 2021-06-12T21:18:31.490+00:00 eventlog[3927]: Pool stats 256: 2021-06-12T21:18:31.490+00:00 eventlog[3927]: AUDIOCTRL- 0 -> ***-65535 POOL_msg: count: 11 2021-06-12T21:18:31.490+00:00 eventlog[3927]: VIDEOCTRL- 0 -> ***-65535 POOL_msg: count: 11 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-65535 -> EPAppl- 0 EPAppl_DiagnosticMessage_Req: count: 30 2021-06-12T21:18:31.490+00:00 eventlog[3927]: PARAGENT- 0 -> ***-65535 POOL_msg: count: 1 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-2051 -> EPAppl- 0 EPAppl_InvokeStdFunction: count: 2 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***- 9 -> ***-65535 POOL_msg: count: 3 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***- 11 -> ***-65535 POOL_msg: count: 1 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***- 46 -> ***-65535 POOL_msg: count: 1 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***- 62 -> ***-65535 POOL_msg: count: 1 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***- 58 -> EPAppl- 0 EPAppl_InvokeStdFunction: count: 3 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***- 12 -> EPAppl- 0 EPAppl_InvokeStdFunction: count: 2 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-2054 -> ***-65535 POOL_msg: count: 1 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-2051 -> ***-65535 POOL_msg: count: 2 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-65535 -> ***-65535 POOL_msg: count: 20 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***- 1 -> ***-65535 POOL_msg: count: 1 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-3987 -> EPAppl- 0 EPAppl_InvokeStdFunction: count: 1 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-65535 -> EPAppl- 0 EPAppl_DiagnosticGroupMessage_Req: count: 6 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-216 -> ***-65535 POOL_msg: count: 1 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-5600 -> ***-65535 POOL_msg: count: 2 2021-06-12T21:18:31.490+00:00 eventlog[3927]: Pool stats 512: 2021-06-12T21:18:31.490+00:00 eventlog[3927]: PARAGENT- 0 -> ***-65535 POOL_msg: count: 2 2021-06-12T21:18:31.490+00:00 eventlog[3927]: AUDIOCTRL- 0 -> ***-65535 POOL_msg: count: 4 2021-06-12T21:18:31.490+00:00 eventlog[3927]: VIDEOCTRL- 0 -> ***-65535 POOL_msg: count: 2 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-65535 -> ***-65535 POOL_msg: count: 992 2021-06-12T21:18:31.490+00:00 eventlog[3927]: Pool stats 1024: 2021-06-12T21:18:31.490+00:00 eventlog[3927]: AUDIOCTRL- 0 -> ***-65535 POOL_msg: count: 3 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-65535 -> ***-65535 POOL_msg: count: 147 2021-06-12T21:18:31.490+00:00 eventlog[3927]: Pool stats 2048: 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-65535 -> ***-65535 POOL_msg: count: 700 2021-06-12T21:18:31.490+00:00 eventlog[3927]: Pool stats 4096: 2021-06-12T21:18:31.490+00:00 eventlog[3927]: AUDIOCTRL- 0 -> ***-65535 POOL_msg: count: 16 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-65535 -> ***-65535 POOL_msg: count: 84 2021-06-12T21:18:31.490+00:00 eventlog[3927]: Pool stats 8192: 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-65535 -> ***-65535 POOL_msg: count: 64 2021-06-12T21:18:31.490+00:00 eventlog[3927]: Pool stats 16384: 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-65535 -> ***-65535 POOL_msg: count: 2000 2021-06-12T21:18:31.490+00:00 eventlog[3927]: Pool stats 36864: 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-65535 -> ***-65535 POOL_msg: count: 40 2021-06-12T21:18:31.490+00:00 eventlog[3927]: Pool stats 64128: 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-65535 -> ***-65535 POOL_msg: count: 2 2021-06-12T21:18:31.490+00:00 eventlog[3927]: Pool stats 73728: 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-65535 -> ***-65535 POOL_msg: count: 2 2021-06-12T21:18:31.490+00:00 eventlog[3927]: Pool stats 100992: 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-65535 -> ***-65535 POOL_msg: count: 10 2021-06-12T21:18:31.490+00:00 eventlog[3927]: Pool stats 339328: 2021-06-12T21:18:31.490+00:00 eventlog[3927]: ***-65535 -> ***-65535 POOL_msg: count: 4 2021-06-12T21:18:31.490+00:00 eventlog[3927]: *** Dumping pools end 2021-06-12T21:18:31.490+00:00 eventlog[3927]: File descriptors 2021-06-12T21:18:31.491+00:00 eventlog[3927]: 0 /dev/null 2021-06-12T21:18:31.491+00:00 eventlog[3927]: 1 socket:[44407] AF_UNIX: Unnamed -> AF_UNIX: /run/systemd/journal/stdout 2021-06-12T21:18:31.491+00:00 eventlog[3927]: 2 socket:[44408] AF_UNIX: Unnamed -> AF_UNIX: /run/systemd/journal/stdout 2021-06-12T21:18:31.491+00:00 eventlog[3927]: 3 anon_inode:[eventfd] 2021-06-12T21:18:31.491+00:00 eventlog[3927]: 4 anon_inode:[timerfd] 2021-06-12T21:18:31.491+00:00 eventlog[3927]: 5 anon_inode:[eventfd] 2021-06-12T21:18:31.491+00:00 eventlog[3927]: 6 anon_inode:[timerfd] 2021-06-12T21:18:31.491+00:00 eventlog[3927]: 7 /sys/devices/7000c400.i2c/i2c-1/1-0050/eeprom 2021-06-12T21:18:31.491+00:00 eventlog[3927]: 8 /sys/devices/virtual/thermal/thermal_zone0/temp 2021-06-12T21:18:31.491+00:00 eventlog[3927]: 9 /sys/devices/virtual/thermal/thermal_zone2/temp 2021-06-12T21:18:31.491+00:00 eventlog[3927]: 10 /sys/devices/virtual/thermal/thermal_zone1/temp 2021-06-12T21:18:31.491+00:00 eventlog[3927]: 11 /sys/devices/virtual/thermal/thermal_zone3/temp 2021-06-12T21:18:31.491+00:00 eventlog[3927]: 12 /sys/devices/virtual/thermal/thermal_zone6/temp 2021-06-12T21:18:31.491+00:00 eventlog[3927]: 13 /sys/devices/virtual/thermal/thermal_zone4/temp 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 14 /sys/devices/virtual/thermal/thermal_zone5/temp 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 15 /sys/devices/7000c400.i2c/i2c-1/1-0018/hwmon/hwmon5/temp1_input 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 16 /sys/devices/pwm-fan/rpm_measured 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 17 /sys/kernel/debug/tegra_fan/target_pwm 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 18 socket:[44612] AF_UNIX: Unnamed -> AF_UNIX: /run/dbus/system_bus_socket 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 19 socket:[46770] AF_UNIX: Abstract -> 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 20 socket:[46771] AF_UNIX: Unnamed -> 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 21 /dev/shm/smcfg 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 22 anon_inode:[eventfd] 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 23 /dev/shm/smbp 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 24 anon_inode:[eventpoll] 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 25 anon_inode:[timerfd] 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 26 /sys/devices/system/cpu/cpufreq/policy0/cpuinfo_cur_freq 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 27 anon_inode:[eventpoll] 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 28 anon_inode:[eventfd] 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 29 /config/pairingdb 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 30 /sys/devices/system/cpu/cpufreq/policy0/cpuinfo_cur_freq 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 31 /sys/devices/system/cpu/cpufreq/policy0/cpuinfo_cur_freq 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 32 /sys/devices/57000000.gpu/devfreq/57000000.gpu/cur_freq 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 33 /sys/devices/system/cpu/cpufreq/policy0/cpuinfo_cur_freq 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 34 socket:[45689] AF_UNIX: Unnamed -> AF_UNIX: Unnamed 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 35 socket:[45690] AF_UNIX: Unnamed -> AF_UNIX: Unnamed 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 36 anon_inode:[eventfd] 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 37 anon_inode:[eventpoll] 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 38 anon_inode:[eventfd] 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 39 socket:[46788] AF_INET6: ::1:9697 -> 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 40 socket:[45691] AF_NETLINK: -> AF_NETLINK: 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 41 /dev/input/event2 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 42 anon_inode:[eventfd] 2021-06-12T21:18:31.492+00:00 eventlog[3927]: 43 /dev/snd/pcmC0D0c 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 44 /dev/snd/pcmC0D0c 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 45 /dev/snd/pcmC0D0c 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 46 /dev/snd/pcmC0D0c 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 47 /dev/snd/pcmC0D0c 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 48 /dev/snd/pcmC0D0c 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 49 /dev/snd/pcmC0D0c 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 50 /dev/snd/pcmC0D0c 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 51 /dev/snd/pcmC0D0p 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 52 socket:[43746] AF_INET: 0.0.0.0:54122 -> 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 53 /dev/snd/controlC0 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 54 socket:[45825] AF_UNIX: Abstract -> 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 55 anon_inode:[eventpoll] 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 56 /dev/cec0 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 57 anon_inode:[eventpoll] 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 58 socket:[44860] AF_INET: 0.0.0.0:1 -> 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 59 socket:[44861] AF_INET6: :::58 -> 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 60 anon_inode:[timerfd] 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 61 anon_inode:[eventpoll] 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 62 anon_inode:[eventpoll] 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 63 /dev/urandom 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 64 anon_inode:[eventpoll] 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 65 anon_inode:[eventfd] 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 66 /dev/urandom 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 67 anon_inode:[eventfd] 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 68 anon_inode:[eventpoll] 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 69 anon_inode:[timerfd] 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 70 socket:[46936] AF_INET6: ::1:2963 -> 2021-06-12T21:18:31.493+00:00 eventlog[3927]: 71 anon_inode:[eventpoll] 2021-06-12T21:18:31.494+00:00 eventlog[3927]: 72 /config/call_history_module_sqlite3.db 2021-06-12T21:18:31.494+00:00 eventlog[3927]: 73 /proc/3927/fd 2021-06-12T21:18:31.494+00:00 eventlog[3927]: Dumping info took 0.010957447 seconds 2021-06-12T21:18:38.391+00:00 video[5206]: tshell: Failed to connect to system software
06-07-2021 12:34 PM
Hello @Jamaljones1978
Can you share a print of error and software version of your Webex Board?
To manually download and upgrade your Webex Board it is necessary a contract, but if you have a Webex Subscription you have right to get updated versions of software automatically as soon as you register it on cloud by activation code.
06-07-2021 02:02 PM
11-30-2022 12:21 AM
Hi, did you manage to clear the Maintenance Mode status? Or was an RMA required?
Welcome to the Webex Community. This is your home to ask questions, share knowledge, and attend live webinars.
