Webex Board Pro with PTZ4K
we use a Webex Board Pro and the PTZ4K as second camera for PresenterTrack. It all works fine but the image of the PTZ4K cannot be mirrored. Nothing is readable over the PTZ4K. Has anyone the same problem?
You should be able to set the Mirror option to On (or the Flip option if you mount the camera upside down).
Note: you will need to reboot the system for this change to take effect, it doesn't happen on the fly.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
