Webex Codec Pro compatibility with BYOD Cable (CAB-USBC-AC-9M=)
IsaacOwen1984
Does this cable (CAB-USBC-AC-9M=) connect to the port labeled with the spanner (Blue dot on snippet)
I assume a recent firmware update enables this cable to work?
Snippet from this doc
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/room-kit/installation-guide/codec-pro-installation-guide-en-fr-es-pt-it-de.pdf
Ashish Patel
Thanks for the links. Really useful.
I have since found that BYOM is not required but only content sharing via this cable CAB-USBC-AC-9M=)..
Would simply Content share from a laptop into the codec pro work using the ciscoCAB-USBC-AC-9M=) cable?
No use HDMI cable below (or attach dongles to an HDMI cable) or webex app with wireless sharing. Mircast (wired LAN needed on codec pro) or Airplay (uses Bluetooth if the antenna are connected and in close vicinity of the sharer) are also options.
See MULTI-HEAD 4K - 9M
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/collaboration-peripherals/datasheet-c78-741432.html
https://help.webex.com/en-us/article/ndlsg3c/Wireless-sharing-with-AirPlay
https://help.webex.com/en-us/article/w60modb/Configure-wireless-sharing-with-Miracast
Thx
ashish
Response Signature
