Webex Desk Mini need to add a camera
beth hatfield
has anyone been successful adding a webcam, or any video source to a Desk Mini? There is only one input- USB C. Is it possible to add a USB webcam as a second camera?
Connecting external USB cameras directly to the Desk Mini isn't something that is currently supported.   As a workaround, you can connect a PC or laptop via the USB-C cable (as long as the device you're connecting supports Display-Port Alt Mode on its USB-C port), and then you can display whatever is showing on that on the Desk Mini.  So, if you had a webcam connected to the PC and displaying on the screen, you could show that as content in to your mini.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Connecting a laptop is not an option. It needs to be video signal only.
