API - Modify alternate phone numbers and extensions
Yoann Le Dréan
I would like to be able to get and modify alternate phone numbers and their extensions via the API.
On the people API endpoint, only the primary phone number can be obtained and modified.
It is possible to get alternate numbers and their extension with the endpoint /v1/telephony/config/numbers, but it is not possible to modify them here.
Is it already possible to manage alternate numbers?
If not, could you add a way to manage them?
kctrey
You are correct that there is no way to do that today. This is actively being developed at this time. It will most likely show up as a /v1/people/{personId}/features/aliasNumbers API or something similar.
kctrey
