Group Details usage property
Stoitsev
Visitor
When using the Groups API there is a "usage" property returned that is not documented what values it might have and what they mean. Can someone please clarify what are the possible values? How would that field look like for a group synchronised via DirSync?
  "id": "Y2lzY2someGroupIdOQ",
  "displayName": "This is a group!",
  "orgId": "Y2lzsomeOrgIdNDk",
  "description": "This is a group description!",
  "created": "2022-05-08T18:25:07.860Z",
  "lastModified": "2022-06-06T10:51:32.308Z",
  "usage": "policy"
Sorry for the delay, we're still confirming on this but initial checks seem to point to this being a bug, as the field is supposed to be kept internal and not exposed. Engineering will look into correcting it, you can ignore it for now.
Raffaele Lagana
We are not sure on this either, seems that it was added to the API but not documented. We're checking with our Engineers, we'll let you know as soon as there is an update on it.
Thanks Raffaele, did engineering come back with an answer on this?
