npm install --save webex error
11082
Community Member
npm ERR! code ETARGET
npm ERR! notarget No matching version found for @webex/[email protected].
Janos Benyovszki
@11082 unfortunately you did not share much info about the steps you are following, only the error message. Please follow the guideline here https://developer.webex.com/docs/sdks/node for installing the JS SDK in your project. Please also test https://github.com/webex/webex-js-sdk/blob/master/CONTRIBUTING.md#running-samples-locally to make sure that you are able to run the SDK. If you need further assistance, we will need a much more detailed description about the exact steps that you are taking.
hazeena farook
This seems like npm err, try checking relevant blogs for npm issues. https://stackoverflow.com/questions/44331005/npm-error-no-matching-version-found-for
