Is there a way to get the call history of a few specific agents?
sebSteve
Basically I want to know how many calls each of them are taking, missing etc but can't find a way to do it without setting up an integration for each of their accounts and using call history. Any ideas of how to achieve this?
Hey
You should be able to do that with the Agent Statistic API
Get Agent Statistics | Webex Contact Center for Developers (webex-cx.com)
The AgentIds is a list of agentIds
Comma-separated list of agent IDs. A maximum of 100 values is permitted. If values are not provided, all agents of an organization are returned.
Return:
  "meta": {
    "orgId": "3dae8fdd-06e2-411a-9035-51f3719f5b65"
  "data": [
      "intervalStartTime": 1591702200000,
      "agentId": "06ce7234-dd3e-49e2-8763-d93766739d",
      "agentName": "Daniel Garrett",
      "teamId": "fbf80248-b328-4c37-9ea5-4c2ec8b4d52c",
      "teamName": "Collaboration",
      "channels": [
          "channelType": "chat",
          "totalAssignedTasks": 3,
          "totalOfferedTasks": 3,
          "totalAcceptedTasks": 3,
          "totalRejectedTasks": 3,
          "totalTransferredTasks": 2,
          "totalEngagedDuration": 40302,
          "totalHoldDuration": 10198,
          "totalWrapUpDuration": 3552,
          "totalAvailableTime": 234947,
          "totalUnAvailableTime": 22300,
          "averageHandledTime": 22300
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Thomas G. J.
Hey
Return:
  "meta": {
  "data": [
      "channels": [
