meeting:transcription:connected event nver triggered
subhojitpaul21
I want to achieve real time transcription with Webex JS SDK. I am using the 3.0.0-beta.303 version of the library. I am referring below resources:
1. https://developer.webex.com/blog/how-to-receive-real-time-meeting-transcription-with-the-webex-javascript-sdk
2. https://developer.webex.com/blog/webex-javascript-sdk-now-has-real-time-meeting-transcription
3. https://github.com/webex/webex-js-sdk/tree/next/docs/samples/browser-plugin-meetings
4. https://webex.github.io/webex-js-sdk/samples/browser-plugin-meetings/
I am testing it with a sandbox account. The real time transcription is working in the kitchen sink app (authenticated with sandbox account access token). However, it is not working in my implementation. I have ensured:
1. enabledWebexAssistantByDefault is enabled
2. Webex SDK is initiated with enableAutomaticLLM
In my case, meeting:transcription:connected event on meeting does not seem to trigger. meeting.isTranscriptionSupported() is false, checked after joining the meeting. meeting.startTranscription() fails with error "startTranscription is not a function".
I am confused what I am missing? It is weird, that with the same token transcription is working is the kitchen sink app.
subhojitpaul21
webex.init() takes a while to initialize. I was able to make it working by wrapping the code inside webex `ready` event.
webex.once('ready', () => {
// webex meetings register, sync, join, etc.
https://developer.webex.com/docs/sdks/webex-meetings-sdk-web-quickstart
8 Replies 8
subhojitpaul21
Janos Benyovszki
@subhojitpaul21 I checked your code, that seems to be fine. I also tested our KitchenSink app https://webex.github.io/webex-js-sdk/samples/browser-plugin-meetings/ with my demo account, that is working fine:
I also noticed that you get the error "Webex Assistant is not supported". This suggest to me that you might be using a site that is using the Webex Assistant instead of the AI Assistant? Note, that there are some limitations when it comes to the older Webex Assistant and the transcripts API (noted here https://developer.webex.com/docs/app-programming-interface-behavior-changes), so it might be the issue here for you too.
Can you test the KitchenSink app with your user and see if you get the transcripts with it? If you do, then it is a code related problem, for which let's open a support ticket - email to devsupport@webex.com .
If you do not get the transcript there either, then it is a site related issue, most likely because you are using the old Webex Assistant instead of the new AI Assistant. To find out how to enable the AI Assistant, see https://help.webex.com/en-us/article/9dofjcb/Administer-Cisco-AI-Assistant-in-Control-Hub .
Hi. With the same user token, I can see transcripts in the kitchen sink app.
@subhojitpaul21 let's continue discussions on the ticket you created for this (ticket #126659), so we can investigate further. I've replied there, thanks.
Janos Benyovszki
@subhojitpaul21 it is difficult to provide recommendations without knowing how your code looks like, but generally I would recommend testing:
- that other events are triggering like other Meeting related ones from here https://github.com/webex/webex-js-sdk/tree/next/packages/%40webex/plugin-meetings#meeting-events ?
- meeting.startTranscription() is a function defined in the meeting plugin here https://github.com/webex/webex-js-sdk/blob/7e6755b407b5d08a41916f8f2f263ee6802ec6a4/packages/%40webex/plugin-meetings/src/meeting/index.ts#L4918 . If you get a "startTranscription is not a function". it most likely means that your package is not correctly set, so please look into that part based on the sample app code
Hi Janos. Thanks for the reply. Basically, I am trying to build an embedded app that should proactively listen to meeting conversation.
The app has HTML and JS. Details:
webex: ^3.0.0-beta.303
@webex/plugin-meetings: ^3.0.0-beta.303
custom JS and modules bundled together with browserify
bundle.js loaded via script tag in index.html
Custom.js
window.addEventListener("load", () => {
    // call https://developer.webex.com/docs/api/v1/meeting-preferences/update-scheduling-options API with
    //     enabledWebexAssistantByDefault: true,
    //     enabledJoinBeforeHost: false,
    //     joinBeforeHostMinutes: 0,
    //     enabledAutoShareRecording: false
// 1. initiate webex
let window = window.webex = Webex.init({
    config: {
        appName: "webex-assistant",
        appPlatform: "webexApp",
        fedramp: false,
        logger: {
            level: "debug"
        meetings: {
            reconnection: {
                enabled: true
            enableRtx: true,
            experimental: {
                enableMediaNegotiatedEvent: false,
                enableUnifiedMeetings: true,
                enableAdhocMeetings: true,
                enableTcpReachability: false,
                enableTlsReachability: false
            enableAutomaticLLM: true
    credentials: {
        access_token: "personal access token from developer portal"
// 2. meetings register
webex.meetings
.register()
.then(() => {
    // 3. meetings sync
    webex.meetings
        .syncMeetings()
        .then(() => {
            let allMeetings = webex.meetings.getAllMeetings();
            let meetingIds = Object.keys(allMeetings);
            // For development - Considering there is only one ongoing meeting.
            const meeting = allMeetings[meetingIds[0]];
            // 4. meeting event registration
            meeting.on("meeting:transcription:connected", () => {
                // never invoked.
                try {
                    // attempt 1
                    .then(() => {
                        //never invoked
                        console.log("transcription started");
                    .catch((err) => {
                        console.error(err);
                catch (e) {
                    console.error(e);
            meeting.on("meeting:receiveTranscription:started", () => {
                // never invoked
            meeting.on("meeting:receiveTranscription:stopped", () => {
                // never invoked
            // 5. meeting join and speak in webex
            meeting.join({
                enableMultiStream: false,
                pin: "",
                moderator: false,
                breakoutsSupported: false,
                moveToResource: false,
                resourceId: null,
                locale: "en_UK",
                deviceCapabilities: [
                    "SERVER_AUDIO_ANNOUNCEMENT_SUPPORTED"
                captcha: "",
                receiveTranscription: true
            }).then((payload) => {
                // invoked
                console.log(payload);
            let meeting = allMeetings[meetingIds[0]];
                // always errors with message "isTranscriptionSupported function not found" and shows message "Webex Assistant is not supported"
                meeting.isTranscriptionSupported();
                try {
                    // attempt 2
                    // failed with error startTranscription function not found
                    .then(() => {
                        //never invoked
                    .catch((err) => {
                        console.error(err);
                catch (e) {
                    console.error(e);
            .catch((e) => {
                console.error(e);
        .catch((e) => {
            console.error(e);
.catch((e) => {
    console.error(e);
Testing steps:
  1. Open webex desktop app and sign in with sandbox admin credentials
  2. Start meeting and enable closed captions
  3. Open the HTML file in local
  4. I expect that real time transcript must be printed in console based on meeting:receiveTranscription:started, but it is not happening
Attempt 1:
meeting.startTranscription() is called inside meeting:transcription:connected, but it is never invoked
Attempt 2:
meeting.startTranscription() is called after meeting join, then it errors "startTranscription is not a function"
Observation:
meeting.isTranscriptionSupported() always returns error message "Webex Assistant is not supported". Even though captions real time transcription is working fine on the kitchen sink app and the webex desktop app. I also ensured enabledWebexAssistantByDefault is enabled before webex init.
Meetings register, sync up till meeting.join() works fine without errors.
What I tried since your last response:
You suggested that meeting plugin might not be loaded. So I added this as well @webex/plugin-meetings, but still there is no change in behavior.
Hi @Janos Benyovszki Based on the code I shared, any idea what else I am missing?
Also, would like to highlight that, as per prerequisite, the meeting webex assistant license is also enabled for the user.
Also ensured this is enabled https://help.webex.com/en-us/article/hzd1aj/Enable-Webex-Assistant-for-devices
