Webinar/event templates in scheduler
Rudrakshi
Query from Carlos Venegas in #webex4devs space
For the XML API for Events, is it possible to use a template to schedule events?. For meetings, we can use it but I don't know if it's feasible to use it at Events
Best regards,
Rudrakshi Srivastava
Mike Palkovich
The scheduling templates can be set for the Classic Events just like it is done for Webex Meetings by using the <sessionTemplate> element which is a sub-element of <metaData>.
You can set a specific scheduling template by name:
<sessionTemplate>
  <use>Template Name</use>
</sessionTemplate>
Or you can select the default scheduling template (configured in the Meeting site settings by an administrator) by setting:
<sessionTemplate>
   <default>true</default>
</sessionTemplate>
Please note that the new Webinars are only supported in the REST API which use the templateId to specify the scheduling templates.
