Regex in Redirect URI
hazeena farook
Hi, can we use regex in redirect uri in OAuth integration app?
hazeena farook
No, it is not possible to use regex. Each URI needs to be added separately in the given space for  while creating Integration.
@hazeena farook okay I have found a workaround using state parameter in URL. Could you please let me what is the maximum character limit allowed in state parameter? and should I encode state parameter?
@kishorshaw94 what exactly do you want to use the state parameter for? To answer your questions:
- yes, you should encode the state parameter, if you want to pass it in full
- not sure about the upper limit for it, but I did successful tests with 550+ characters in the state parameter
