Sync mute button status on microphone device
miazhang
I would like to know how the mute message is transmitted between Webex and the device, and if it is possible to realize mute synchronization and Whether mute synchronization can be controlled by HID communication.
Is there documentation available to refer to or explain how to do this? I want to develop my device to realize the mute synchronization function.
hazeena farook
Can you try checking here https://roomos.cisco.com/xapi/search?search=mute ?, make sure you choose the right device details and version in search to see the available commands for Mute functionality. If you are looking for the internal functioning of how this command is treated and processed, then I am afraid that we will be able to guide you on this.
