WCC Functions
phani venigalla
Frequent Visitor
Frequent Visitor
How to Find the length of Collect digits and Substring functions in WCC Flow Editor
2 Accepted Solutions
Arunabh Bhattacharjee
You can use the length filter using pebble
{{ digitString | length }}
Hi Phani for the date time manipulation you can use the DateTime data type
This video may help you with working with time of day in flow:
https://app.vidcast.io/share/7823992c-68b8-46be-9c3d-15ac3476f1d3
Some other resources:
For Pebble methods etc - you can refer the official documentation:  https://pebbletemplates.io/
There is an unofficial Pebble Parser app that is a cold start (it is hosted for free, takes 30 seconds to start)
Pebble parser learning App - https://pebble-parser.herokuapp.com/
To learn more on how to use it go to Info > About
It throws the full stack trace for debugging so is easier to debug while manipulating data inside flow.
Thanks & Regards,
Arunabh.
11 Replies 11
phani venigalla
Frequent Visitor
Frequent Visitor
Hi Arunabh,
i am trying to access the length of the json array response(like number of Transactions) with json path expression "$.length" but, it is not working in the parse element of webex flow designer. We are taking the https json response to variable and taking the length.But its not getting the length.
Help appreciated.
For some reason Parse element is not working. trying to access the data out of JSON response.
The JSON path expression which is gtting $.lenght same function is not working in WCC parse element.
Thank you!, is there a document for all the Java script functions , Like Compare, We also have a requirement to compare and convert the date format from MMDDYY to YYYYMMDD, since the date comes from webservices as YYYYMMDD.
Thanks & Regards,
Arunabh.
Hi Arunabh,
How do i convert the date comes from API
/Date(1656689365077-0500)/ to MMdd format?
Pl let me know the input format of that Date to be converted.
Phani.
Hi Anurab,
In flow designer Collect digits node , how do we set retries if no entry or no match.
Phani
You can refer the advanced settings in the node. No input timeout and unmatched entry are already exit blocks.
So you can increment a counterVariable that stores how many times you want to retry the operation and loop back,
That would be a standard counter and Set Variable counter to {{ counter + 1 }} and then a conditional block.
I have written this below function in Setvariable. I could parse in PebbleParser and in SetVariable Expression as well. However when i assign to Variable i am getting synatx error. Getting "Variable value cannot contain spaces. double quotes and line breaks etc..." : Help me what wrong on this sysntax.
{% set k=k_str3  | replace({"Date(" : ""}) | replace({")" : ""}) %}{% set l=k |slice(0,k.length()-5) %}
{{l | trim()}}
Date(1659589200000-0500)
Output : 1659589200000
Hi Arunabh,
Help appreciated.
Phani.
