WebEx Contact Center Customer Call Experience
sp17
I'm trying to track down information of overall customer experience. When customer calls in and is transferred from Agent A -> Agent B -> Agent C before hanging up. so details like customer number, how many times that particular customers called in and whether it was answered successfully or abandoned.
Is there any API or Report I can use? If information is in multiple APIs, how can link it? Is there any process or flow I can refer?
Thank you.
Arunabh Bhattacharjee
Hello @sp17
You could use the Search API on the Contact Session Record: https://developer.webex-cx.com/documentation/search/v1/search-tasks there is also other objects exposed like AgentSession, TaskDetails, TaskLegDetails etc
To understand how to use this API, refer the GraphQL samples - under reporting samples
https://github.com/WebexSamples/webex-contact-center-api-samples/tree/main/reporting-samples/graphql-sample
  the video is embedded in the readme
You can copy paste any of the examples directly into the graphiQL editor to test.
E.g
all contact fields
https://github.com/WebexSamples/webex-contact-center-api-samples/blob/main/reporting-samples/graphql-sample/allContactFields.graphql
all agent session fields
https://github.com/WebexSamples/webex-contact-center-api-samples/blob/main/reporting-samples/graphql-sample/allAgentSessionFields.graphql
For things like how many times per ANI etc you can use aggregations and formulas
E.g https://github.com/WebexSamples/webex-contact-center-api-samples/blob/main/reporting-samples/graphql-sample/totalCallsByAni.graphql
Thanks & Regards,
Arunabh.
Hello @sp17
E.g
all contact fields
Thanks & Regards,
Arunabh.
