ā10-12-2022 05:34 AM
Is there an API available in Webex which helps us to get the report on call history for only Webex to Webex calls.
ā03-26-2025 07:04 AM
As I can see, this information is available in this section:
In this section, you can see the calls on webex and meetings.
My question: Is it possible to get the same information from API
ā10-12-2022 02:11 PM
Hi @vbj1995,
There is no API for generating report on call history for only Webex to Webex calls. The available API generates report for overall call history.
Also, in the generated report, it is possible to filter call history for Webex to Webex calls but it is not EASY task. In the call history report, each call has at least two call legs (Originating & Terminating). You need to sort the calls to make sure their call legs match. See attached screenshot.
ā12-01-2022 12:40 PM
Hi Vaijanath,
What is the API that generates the Cisco Webex Calling Call History Report?
ā12-01-2022 12:54 PM
See https://developer.webex.com/docs/api/v1/reports, specially the one for creating reports.
You may also have a look at https://developer.webex.com/docs/api/v1/report-templates to identify the template you need.
ā12-02-2022 07:59 AM
Thanks @dtibbe,
an additional question, is there any API or protocol that allows obtaining the CDR in real time? This is for a hotel solution.
thanks
ā12-02-2022 08:13 AM
Currently, there is not. I think Cisco is working on a dedicated API.
Per user one may utilize webhooks or even XSI, but that won't help in your case
ā10-13-2022 04:09 AM
On the CDR list we have many client types which one indicates Webex calls.
ā10-12-2022 01:05 PM
You may also check the Calling Reports in CH (which may also be created by API): https://help.webex.com/nmug598/
At least the Call Engagement and Call Qualitiy reports list the Calls on Webex, the Call Detailed Report is for Webex Calling only IIRC.
I think the Endpoint Type will help you to distinquish between WxC and CoW
ā10-12-2022 12:56 PM
Control Hub may have what you're looking for. Go to Analytics and select Calling. One of the dashboards is "Call Legs by Endpoint Type." It's not clear in the description if this is just Webex to Webex but when I drilled down to the users listed in the report, all of them only had Webex endpoints. I couldn't find any with a PSTN endpoint.
ā10-13-2022 04:11 AM
Thanks for the suggestion but I am looking out for an automated solution to fetch Webex to Webex call history details.
ā10-14-2022 09:16 AM
Hello @vbj1995 you can use the API to automate this process. Please see the Reports API.
As suggested above, Call Engagement and Call Qualitiy reports list the Calls on Webex. When you will need to start by Getting all report templates, then look for the templateID associated with Call engagement, use this templateID to generate call engagement report which is what you are looking for.
