Andriod Mobile - Sync Contacts to Webex
ACA UK
I'm needing to find a way to sync my contacts in my andriod mobile to the Webex app. As I use Outlook for all my contact information, it is unreasonable to require me to maintain 2 sets of contacts. Is it possible to grant Webex access to my contacts? Similar to WhatsApp etc.
dtibbe
Yes, that is possible.
You may use the global search to search for your mobile contacts. They will show up below the found spaces and Webex contacts as "on my device" (or similar, I'm using the app in German
Thank you for your reply. I didn't know about this method but it seems to be a way to search and then import contacts into the  webex app. I'm guessing this is not the same as syncronising the contacts between the phone and app? BR
