Vaijanath Sonvane
Below procedure describes the steps to restrict Outgoing Calls from User/Workspace Phone registered with Webex Calling:
1. Login to Webex Control Hub
2. If you want restrict outgoing calls from User’s desk phone then go to Users >> select User >> select Calling tab:
3. If you want to restrict outgoing calls from Workspace desk phone then go to Workspaces >> select Workspace >> select Calling tab:
4. Scroll to Call Handling section and select Outgoing call permissions:
5. Under Outgoing call permissions section, select “Custom Settings”:
6. Select Call Types and Permissions to “Allow”, “Block” or “Require Authorization Code”
7. Once all permissions are setup, click Save.
Welcome to the Webex Community. This is your home to ask questions, share knowledge, and attend live webinars.
