05-20-2021 07:31 AM
I am a new user, so I am sorry in advance if my question has already been replied to.
I have a Webex address with my name, as part of my organization (a university). But since I am in charge of organizing an online conference with multiple parallel session, I would like to create 5 different addresses with specific names, in order to host the different sessions of the conference. For example:
Solved! Go to Solution.
06-13-2021 10:46 AM
Hi, you can do this with personal meeting room IDs. You'll have to create user accounts for each conference room ID you wish, which may mean working with your IT department if you use SSO, as that can be tricky with non-user associated accounts, but it is doable.
But, once you have a user ID for each conference room you can see the section called "Change the URL for a User's Personal Room" in this document: https://help.webex.com/en-us/nk4o0ym/Manage-Personal-Rooms-for-a-Webex-Site-in-Cisco-Webex-Control-Hub
06-13-2021 10:46 AM
06-14-2021 01:41 AM
Thank you for your reply. Since it was too complicated, we will finally go with the breakout sessions solution.
