How to share PPT slide deck AND presenter view slide notes
anthonye
What is the best way for a presenter to share a PPT slide deck and also view their PPT notes?  This with one screen.
Thanks, Anthony
FedRAMP (cluster f)
Clare Davis, Webex SME
Hi Anthony - There is a way to do this without a second screen, but there are some limitations if you have animation or if you are using video conference devices to join the session... I created a quick doc to show you how.
Response Signature
Response Signature
John Steele
You can only do this with a second screen.  I suggest you post the idea on aha or it might already be there for you to upvote.
https://ciscocollabcustomer.ideas.aha.io
