AIR-ANT1728 Antenna
Francis Jr Asis
Anybody from you guys can help me. What is the maximum distance or safe distance this antenna can cover. I am using Aironet2602E access point. Because i couldnt understand the radiation pattern. There is 5 circle in the Radiation pattern but i dont know how to convert this is distance. Its only showing the DB.
7 Accepted Solutions
Leo Laohoo
AIR-ANT1728 on a 2602E????  Seriously?
You are about to get into serious strife with this combo ... Let me explain:
1.  If you put the antenna standing on it's tip, you get a 360-degree coverage.
2.  You put the antenna on it's side, this is where you see the pattern of a three-leaf clover.  The spaces between are called "lobes" or in a different word, "shadows".  You won't get good signals when you are standing under the shadows.
3.  Distance?  Depends on the combination of #1 and #2.  And this is where you'll get a fun time getting into trouble.  Let's say you want to MEASURE the maximum theoretical distance.  If you are in a large open field and with no wireless interferrence around, the antenna is installed around 2-3 metres from the ground, pointing downwards, and you are not standing under the "shadows", you'll probably get 50-60 metre coverage.
Now, let's say you have a wireless device at that distance and you're trying to send and receive data, you won't get that far.  The antenna is a mid-gain antenna strength, -5.2 dBI but your wireless clients will NOT have their on-board antenna with this much power.  So what's going to happen is that your clients (out in the field) can "see" or "hear" the wireless signal but the AP will not be able to see any response from the wireless clients because the signals coming back are too faint.
If you insist of using this single-band antenna on a dual band AP, like the 1600E, 2600E, 3500E, and 3600E, I recommend you disable the 802.11a/n radio.
IMPORTANT:  Exactly WHAT are you trying to achieve?
Thank you very much for taking the time and effort to rate our posts.
The new generation of APs are 1602, 2602 and 3602.  All of these have dual radios.  So whether you like it or not, you can't get a single-radio AP.
Almost everyone will tell you that you need to get a comprehensive wireless site survey done.  Anything can go wrong when you do a wireless implementation in a warehouse, regardless of what model of AP you are going to get.  It gets even worst when your hand-held scanner won't work as advertised even though their sales brochure say so.
Look at this document.  Take note of Tables 5, 6 & 7.  These are the antennas designed to work with the APs mentioned above.  Unlike the 1728, you don't need to buy four per AP.  Instead, you just buy one and you connect the four RP-TNC pig-tails to each antenna socket.
The most important questions are:  HOW MANY APs, HOW HIGH, WHERE do you install the APs in the warehouse.  These simple (but difficult) questions can be answered with a wireless site survey.
May I also suggest that, before you wait for the final result of the wireless site survey, you test the compatibility of the wireless AP of your choice and the hand-held devices?  You may also need to consider purchasing a wireless LAN controller (WLC).  My recommendation is the 5508.  The choice for the 2602E for the warehouse floor is a good choice as it's not too expensive.  If you plan to put APs in the office, choose the APs with built-in antennas like the 2602i or the 3602i.
As per in the table i can't use this antenna in this AP.
Ummmm ... You technically can.  You just ensure you disable the 802.11 a/n radio.
If i will use this antenna AIR-ANT2524DB-R= (Dual Band Dipole) in the same setup AP.
Ummmm ... still doesn't make any sense.  The gain of these type of antennas are the same as the gain of the 2602 with internal antennas.  You may as well use 2602i and install the AP against the shelves at around 5 metres from the ground.
Your AP spacing don't have any factor in case an AP in the middle fails.
I will have to reiterate the operational need and significant of a wireless site survey to be conducted.  The simplest way would be to put two APs in a single aisle and measure the signal with a laptop.  This method is not a sure-fire method, but if your client is cheap then, I guess, this will do (gulp!).
George, Scott, Steve, Surendra, you gents have any opinion?
In this antenna what is the safe distance per AP?
If you allow all data rates, I would say yoiu can get a distance of 20-25 metres (802.11 b/g)
Install the APs 9 metres from the floor.
Make sure the antennas are pointing towards the floor.
Along each aisle, I'd put an AP spaced every 20-25 metres.  This caters for redundancy, in case one of your AP fails, the other AP can increase power.
And, for goodness sake, organize for a wireless site survey!
NOTE:  "Sir" Leo?  Last I checked, I haven't been knighted yet.  I got "clocked", but that's another story.  LOL
Scott Fella
Wow what a great weekend read:) Sir Leo is correct on his explanations. So I guess I will put in my 2 cents. I have done a recent warehouse using the AIR-ANT2544V4M-R= with 3602e's. the 3602e's was the customer standard and would work the same for the 2602e's. Now I had these up on about 12 meters and had no issue at all. Now understand what Leo mentioned earlier because its important. You need to match the TX power (EIRP) from the client and the AP to get you the best result. If you don't, we'll it may still work, but you have to understand that whatever signal you see from your client to the AP isn't what the AP sees from the client. Using these single antennas with 4 leads is really the best way to go. You don't have to worry about how far each antenna should be separated and having to deal with mounting 4 seperate antennas. Like Sir Leo mentioned, the days of a single antenna is long gone and its due to having to keep up with the wireless technology. Diversity in a warehouse or really any environment is almost required unless your in an open field with nothing around.
Never look at, well this is what the client wants:) look at what needs to be done to make the wireless work well. If you listen to your customer and use a single antenna, well what happens if they have issues. It's easy when they have an autonomous setup, but things change very fast when you go from autonomous to lightweight.
-Scott
Any switch that is gigabit and supplies 802.af unless you put a module in. Then you need the switch with enhanced PoE. I doubt you will need to add a module in it for the warehouse but just in case, you know what you need.
-Scott
Consider i will use the 3620e AP what is the best L2 switch i could use?2960 is enough for this? The core switch WS-C3750X-12S-S
Core switch of 3750X-12S is good because this means you can position your switch to be in the centre of the location of the APs.
I'd rather use 2960S instead of plain 2960 PoE.  The reason why I'd prefer 2960S is the potential to use 20.0w PoE instead of 15.4w PoE.
You may also want to invest in running multiple fibre optic from the core to the location of the 2960S.  This way, you can configure multiple fibre optic ports into Etherchannel.  This takes care of potential bottleneck (not that you'll be seeing them) and redundancy.
If you are not sure, post the model of the 2960 or 2960S you need, the SFP/SFP+ module your client approves of and we'll give you some feedbacks.
Another thing.  The maximum cable distance from the AP to the switch to do both GigabitEthernet and PoE is 100 metres.
25 Replies 25
paolo bevilacqua
Wrong forum, post in Wireless. You can move your post using the acions panel on the right.
Leo Laohoo
Thank leolaohoo. Its a great information for me. THis is my first time to install AP in warehouse. If you dont mind will you help me to design the wireless position. I am going to install wireless access point in the ceiling  inside the warehouse which i heard a lot of comment that because of metal stub i will get a lot of destructive interference. I have  question also. If i will use the aironet 2602e, can i use only one ant1728 antenna per aironet 2602? because i notice it come with 4 connection for antenna.
My problem is the client need us to install 2600 series(Inside the warehouse) together with AIR-ANT1728 antenna
and 1600 seies (In the Office). They already have the wireless LAN controller. Is there AP 2600 series with only one radio? I will attach a drawing. I made the location of the AP. It would be better if i could send the autocad drawing.
The the height = 10 m
distance per AP = 20 m
There is no such thing as a single-radio 2nd Generation AP which the 1602, 2602 and 3602 belong to.  The 3500 has single radio available.  You may want to offer that to the client.  But, again, still doesn't make any sense because this means that you need to buy three of the antennas PER a single AP unit.
My recommendation is put a spreadsheet.  Put down the cost of the 2602E plus the integrated antenna.  And then below that, put the cost of the 3501E (802.11b/g only) and three pieces of the ANT1728.  Let the client see and choose which proposition they want.  If they still want the 2602E plus the ANT1728, put it down but you need four antennas per a single 2602E.  It sure does NOT make any sense.
Again, the gain of the antenna is too strong to hear back the return signal from the clients.
I can't comment on the 1600 because I for one refuse to deploy this particular model.  I'm not saying that it's a bad model, I just don't want it.  If your client wants cost, try the AP700.
Nuts.  I'm looking at the layout of the warehouse.  How high are these shelves?  You may want to consider install the AP hanging from the ceiling and approximately halfway down the height of each row of racks.  Are there any pallette lifter machines?  If there are, then you may now consider "wall-mounting" the APs from the shelves.
Again, too early to tell.  A simple wireless site survey can answer alot of questions.  Heck, at that height, I WOULD NO LONGER recommend the ANT1728 because of the horizontal footprint.  You're going to hit alot of shadows.  Judging from the height of the shelves, I am thinking about 2602I instead.
EDIT:  Another thing, in a warehouse, someone needs to understand the concept of co-channel interferrence and how it can potentially create havoc.  This is evident in an environment when the hand-held clients only support 802.11 b/g.
Why should i do just to use the 2602E AP. Can i disable the 5GHz radio in the AP because the ANT1728 work in 2.4 GHz. I bit confuse about 3 antenna per AP can i use only one antenna to work in this AP?it is possible just to comply? My spacing of AP is enough to cover the area?
Yes you can.  I've mentioned this in my first post.
The days of an AP with one antenna per radio is long gone.  2602E/3602E have four antenna ports because of MIMO.  Two antennas are receiving and two antennas are transmitting.
This is why I''ve been saying all along that using ANT1728 on APs like 1602E, 2602E, 3500E, 3602E doesn't make any sense.  I'm not saying it WON"T work.  I'm saying that it CAN and WILL WORK but you need to buy three or four antennas per AP.  The costs alone just simple don't add up.  Heck, factor in installation cost and it still doesn't add up.
I can't determine the height and length of the shelves.  You also didn't mention how high (from the floor) are the APs will be installed.
Nuts.  I don't think the APs can cover if any one of them fails.  No redundancy.
Now i get your point. Why it doesn't make any sense using  2602 AP in ANT1728 antenna. As per in the table i can't use this antenna in this AP.
If i will use this antenna AIR-ANT2524DB-R= (Dual Band Dipole) in the same setup AP. The data below will be the safe side to cover the area.
The height of the shelves = 8 meter
The height of the AP = 10 meter
The spacing between them AP = 20 meter
The horizontal spacing line of  multiple AP = 5 meter
Sir Leo i really appreciate your time in helping me to understand in wireless deployment in warehouse. Its a big information for me. Now my last choice is to use this antenna AIR-ANT2544V4M-R= (Dual-Band Omnidirectional Antenna).
In this antenna what is the safe distance per AP? Will still safe to install in the height of 10 meter from the floor? Because we are not allowed to install the AP  against the shelves specially in 5 meter height. Our only choice is 9-10 meter ceiling mount.
that for compliment for someone like you.LOL
Thank you very much
Hi LEO, Would you please tell me is there some advantage for warehouse enviroment with 3602e compare with 3602i .
Thank you !
