AP(AIR-AP1832I-E-K9) not joining with Controller AIR-CT5520-K9
midlajnp1
Dear All,
My access point 1832I didn't join with the controller 5520,
I have connected 9 Aps all of them got the same result.
I attached here the error message and version information for both AP and Controller.
Please can anyone has the solution for this issue, please let me know. Thanks
Hi @midlajnp1
According to Cisco Compatibility Matrix, you need to upgrade your WLC at least at 8.1.122.
Please check (Table 6) https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
