AP migration from AD DHCP to Infoblox DHCP
latintrpt
we are looking to migrate our access points off an AD DHCP server over to Infoblox DHCP server.  We have dedicated subnets for the access points.
The DHCP scopes will remain exactly the same between the two appliances.
Any advice as to how to move these AP's over without a complete outage?
Thank You
What is the lease time for AP management IPs ?
If you have longer lease time for APs, then your DHCP change may not even impact AP. As long as AP retain the IP you won't face any distruptions.
Only thing I would do is increase lease time if you configure short value for that
Rasika
*** Pls rate all useful responses ***
