AP not taking the command
Visauk47
Level 2
Level 2
Hi Guys,
show ap dot11 5ghz summary -- cmd is not working in CLI, any idea why ?
And also can someone plz share some links where I can get some info on cli commands.
it is not an AP CLI command but a controller CLI command.
More specific for converged access networks.
Converged access design uses switches with builtin controllers (models mentioned by Sandeep)
Depending on the ios software in the AP you can search for the other CLI commands.
lke this: Cisco IOS Configuration Guide for Autonomous Aironet Access Points Cisco IOS Release 15.2(4)JB3a
this link Configuring Radio Resource Management includes the command you query and contains some info about other CLI commands on 3850 switches for converged access
5 Replies 5
Visauk47
Level 2
Level 2
AP is 3702
Sandeep Choudhary
I think it will work only if you have IOS-XE(3650/3850) devices who are managing LAPs.
Dont forget to rate helpful posts
Thanks pieterh
Thanks Sandeep.
