05-26-2020 07:36 PM - edited 07-05-2021 12:05 PM
Hello guys, so i just got my first job as a Network Engineer some months ago, but the person who was in my position before me, completely destroy the networking infraestructure, i've been fixing errors all this months and i think i'm doing a great job.
So anyway, last monday i received an AIR-AP2802I-A-K9C, this AP is not compatible with my WLC OS, the WLC is running 7.6.130.0
So my boss told me that the old Network Engineer said that this AP can operate by himself running Mobility Express (that explain why the AP model ends with a "C" which means this AP is running mobility express if i'm right), i investigate a lot and i think this isn't posible, but i would love to have other opinions.
My question is: Can i somehow configure to AP to operate by himself and co-exist with the WLC environment?
Please let me know if i need to put more information here, or if this post goes in other section, thanks everyone.
Solved! Go to Solution.
05-26-2020 07:38 PM
05-26-2020 07:38 PM
05-26-2020 07:46 PM
Thank you very much!
To be honest, i don't have much experience with Mobility Express solution, so, i just need to configure it normally? i mean, the AP that is running Mobility Express can work in the same vlan as the others AP's or do i need to configure a specific VLAN?
Thanks for your quick reply!
05-26-2020 08:18 PM
05-26-2020 08:21 PM
05-26-2020 09:28 PM
Thank you very much for your recommendation.
My boss is negotiating for upgrade the WLC to a version that is compatible with this AP, but in the midle time of this he wants the AP to be working, that's why i start investigating this
So short answer: is doable but i shoul'd do it.
Ok so in the worst case if i need to do this, any recommendation?
05-26-2020 09:55 PM
05-27-2020 03:31 PM
Thank you very much, i'll talk to my boss and try to update the WLC ASAP, thanks.
05-27-2020 08:58 PM
05-29-2020 02:31 AM
05-29-2020 08:47 PM
Hello!
Yeah, i already investigate the best version for my necesities
The version already running is: 7.6.130.0
And the new version will be: 8.3.150.0
The oldest APs that i have are from the series: 1140 and 1260, so i think that this version will be the best for me!
I really appreciate your concern, if you have any suggestion i would love to read it!
05-30-2020 02:01 AM
