Hi All,
Am I doing wrong or is there some software problem not sure.
We are trying to join Cisco 1700 LWAP with Cisco WLC 5520 8.1.110. and getting following error
*Mar 14 05:32:54.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.17.x.x:5246
*Mar 14 05:32:54.999: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config failed, trying backup...
*Mar 14 05:32:54.999: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak config failed...
*Mar 14 05:32:54.999: spamInitRadCfg: recovery image default mode 0
*Mar 14 05:32:55.011: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config failed, trying backup...
*Mar 14 05:32:55.015: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak config failed...
We are able to ping WLC, DNS from AP and did CISCO-CAPWAP-CONTROLLER entry in DNS server with WLC management IP.
Can anyone knows what I am doing mistake.
Kamlesh
8.1.110 has been withdrawn by Cisco. Any chance you can upgrade to something else, like 8.1.131.0 or 8.2.100.0?
This is a troubleshooting guide for access points not joining.
Try (form the console) manually joining the AP to the controller.
"debug lwapp console cli"
or
"debug capwap console cli"
lwapp ap controller ip address <IP-address>
Hi Philip, Thanks,
It was due to Nexus vPC misconfiguration portchannel.
Loading the image has failed, try to upgrade if possible.
