Cisco Aironet 2602 speed up to 54mb/s ??? How to get higher speed?
kaliusuk1
Hi.
How to setup speed higher than 54mb/s? I can't see any option to enable any higher than 54.
I'd like to set this AP as standalone unit to connect a few devices on N speed.
Please advise.
Change these and try again:
dot11 ssid HOME
vlan 1
authentication open
authentication key-management wpa
authentication key-management wpa version 2
guest-mode
wpa-psk ascii 7 071F3B5B400D1D1F16
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
encryption vlan 1 mode ciphers aes-ccm
ssid HOME
Dont forget to rate helpful posts
10 Replies 10
Philip D'Ath
We need to see your config.  Make sure you are not using TKIP.
Hi.
Thanks for reply. I am sorry but I'm complete newby Cisco. I am only using GUI. What kinf of info do you need and how can I retreive it all?
Just to let you know this AP need to be working like normal AP at home with highest possible speed nad stable work. Thanks in advance.
are you using  either open or WPA2/aes encryption for ssid ?
Also paste the config from CLI..
Appologies for my little knowledge, but how can I access CLI to give all details throught GUI?
Please advise.
PS. I will rate all helpfull comments.
Thank you.
do you have access to AP via Telent/ssh or console ??
If yes then run this command "show running-config"and paste the complete ouput.
User Access Verification
Username: Cisco
Password:
ap#show running-config
Building configuration...
Current configuration : 2163 bytes
! Last configuration change at 00:02:33 UTC Mon Mar 1 1993
version 15.2
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$AZOP$xeaERKaX7i0bMlCpcNQ4t0
no aaa new-model
ip cef
dot11 syslog
dot11 vlan-name Home vlan 1
dot11 ssid HOME
vlan 1
authentication open
guest-mode
information-element ssidl advertisement wps
dot11 network-map
username Cisco privilege 15 password 7 14341B180F0B
bridge irb
no ip address
ssid HOME
antenna gain 0
stbc
speed basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23.
channel 2462
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
shutdown
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
duplex auto
speed auto
interface GigabitEthernet0.1
bridge-group 1
interface BVI1
ip address 192.168.0.25 255.255.255.0
ip default-gateway 192.168.0.1
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip route 0.0.0.0 0.0.0.0 192.168.1.1
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
What I noticed is that speed is very slow over wifi and after a couple hours connection keep cutting or takes longer than ususal to connect. I imagine config have to be completely rebuilded.
dot11 ssid HOME
vlan 1
authentication open
guest-mode
no ip address
ssid HOME
Shall I just type this in telnet session?:
and confirm by enter?
Also on some forums people were saying to use 5Ghz insead of 2.4. Is this what I need to change as well?
Still can't use more than 54mb/s. Even change radio to 5Ghz
I couldn't find:  aes-ccm
See log:
Username: Cisco
Password:
Current configuration : 2256 bytes
! Last configuration change at 00:02:37 UTC Mon Mar 1 1993
version 15.2
no service pad
hostname ap
no aaa new-model
ip cef
dot11 syslog
dot11 ssid HOME
vlan 1
authentication open
guest-mode
dot11 network-map
bridge irb
no ip address
antenna gain 0
stbc
channel 2462
station-role root
bridge-group 1
no ip address
ssid HOME
antenna gain 0
no dfs band block
stbc
power local -4
channel width 40-above
channel dfs
station-role root
interface Dot11Radio1.1
bridge-group 1
no ip address
duplex auto
speed auto
bridge-group 1
interface BVI1
ip http server
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
Please help
For testing, try an open SSID and see if your device can connect at a higher data rate.
-Scott
-Scott
