Cisco wireless cards and ipaq software
jag
I know that they work, but do all the Cisco programs work with the Ipaq's and Pocket type PC's??? Main question, Can I use the Link Status Meter on a handheld and the other utilities in the Cisco software???
Thanks!!!
tepatel
Cisco software in IPAQ is just to run the wireless card and to supports its features..All the other application programs works with the IPAQ operating system. So the other utilities will not work "in cisco software" but should "work with cisco software" on same IPAQ.
ndoshi
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/350cards/win_ce/hig/ce_ch6.htm
On the IPAQ with CE or other handheld device , you can install Cisco ACU for CE device . Cisco has ACU for Windows 95 , 98 , 2000 , CE , Macintosh , Linux
, Dos .
On IPaq and Pocket PC you can run Link Status Tool . Infact that is strong site survey tool .
Thanks!!! That helps alot!! They came in yesterday and we can't wait to use them instead fo the laptops!!!
Thamks again!!
Jimmy
