CISCO876W-G-E-K9 - SSID are not visible
jgeralsky
Hello All,
I am new one in wireless topic and I have one simple question.
CISCO876W-G-E-K9, we have 2 SSID enabled.
Unfortunately both SSID are not broadcasted (visible) and clients cannot see them.
The clients must setup SSID manualy and then are able to connect to Wi-Fi network.
Where can I setup broadcasting SSID on CISCO876W-G-E-K9 ?
Thank you very much.
Jan
Hi Jan,
Please forward the following output:-
show run interface dot11radio 0
Please note that you have to also add command mbssid under the radio interface
For ex:-
mbssid
Do let me know if you have any queries or concerns.
Shubham
Don't forget to rate helpful posts and also mark this question as answered.
Hello Brett,
here is the thing :
The current configuration :
dot11 ssid SPI
   vlan 2
   authentication open
   authentication key-management wpa
   mbssid guest-mode
   wpa-psk ascii 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
dot11 ssid SGAD
   vlan 1
   authentication open
   mbssid guest-mode
but this output show the guest mode is not enbaled.......................
Router#show dot11 bssid
Interface               BSSID         Guest  SSID
Dot11Radio0   0023.331f.3120  No   SPI
Dot11Radio0   0023.331f.3120  No   SGAD
The current version which is running at Sulz location is 12.4(15)T10.
(c870-advsecurityk9-mz.124-15.T10.bin)
Is this a bug ?
Thank you,
Jan
Hi Jan,
For ex:-
mbssid
Shubham
Hello Shubham,
You are right !
There was missing command mbssid under dot11radio 0.
mbssid
Now, both SSID are visible.
Jan
