HA Options on 2 x 2504's running 8.2.141 ?
Cormac Champion
Hi all,
Many questions have been asked about HA for 2504's but these were running old 7.x versions and some have also had secondary units with zero licences.
I have 2 x 2504's with 5 licences on each, and running 8.2.141.  Can I do the AP SSO HA Option or can I only do N+1 ?  It appears to me that the software will allow me to setup a controller as either a Primary or Secondary setup of Redundancy Management interface ip's
 Still not supported. You see this on the release note of this version.
Search for SSO:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn82.html
-If I helped you somehow, please, rate it as useful.-
2504 only support N+1
No SSO support
Rasika
*** Pls rate all useful responses ***
Search for SSO:
Scott Fella
Like the others mentioned it’s not supported and will never be. The replacement 3504 supports SSO.
-Scott
Leo Laohoo
2504, which Cisco has announced End-of-Sale (18 April 2018), only supports N+1.  The replacement, 3504, support HA SSO.
