Migration from Aruba to Cisco
JMG2020
Hi Experts,
I am migrating the Aruba WLC's to Cisco 3504 in an office.
The users connect to XYZ SSID, once i migrate the controller and AP's to Cisco and the Cisco AP's broadcast the same SSID will the user PC automatically connect or they have to connect manually ?
How do i make sure they do not have to connect manually ?
 - As you are already saying this will more depend on the client-platform/os/wireless-environment then on your new Cisco based wireless infrastructure, it all depends on how 'comfortable' the client feels for auto-connect or not also depending on the offered auth-parameters by the Cisco based SSID.
 M.
Scott Fella
Hard to say without understanding your migration and what you are going to do and when. As long as the SSID’s have been tested and is working then you will see a glitch. It’s best to disable the SSID’s for a few seconds and then enable the SSID’s on the new controller if you have both up. If you are dealing aps, well roaming will break. So depending on how you are migrating.
-Scott
okay.. I have tested the SSID on Cisco
I will be shutting down the Aruba controllers completely which will disable all the Aruba AP's
so once i have only Cisco controller and Cisco AP's broadcasting the same SSID which Aruba used to broadcast a day before.. and the user come to office and turn on their laptop will they have to manually click on connect on the SSID to connect (considering they were connected a day before with the same SSID but using Aruba)... {assuming everything 802.1x authentication and all other parameters are already tested on the Cisco before migration}
 M.
