multiple channel -ap sniffing
wyfy-2015
If  I want to sniff multiple channel (for example roaming  )  using multiple ap's  , What is the best way to do this
George Stefanick
If your doing it with aps, each sniffer ap would have to be on the same channel as the ap you want to sniff. So if you have 10 aps, you need 10 sniff aps. Then you need to ascend the sniffer aps to wireshaek. In my case I use the omni peek wifi appliance.
Does omnipeek also requires multiple adpater ?
Yes, correct. Each nic per channel
