AIR-CAP2602I-E-K9 in Autonomous Mode
iantaylor1
I have a AIR-CAP2602I-E-K9 to play with, I've converted it too Autonomous AP.
I want to create three SSID's
1x for GUEST Access on VLAN23
1x for MOBILE (phones etc, using WPA2-Enterprise)
1x for LAPTOPS (WPA2-Perosnal)
I cannot see anywhere on this WAP referring to WPA2-Enterpris?
I want to be able to use the SSID MOBILE to use my raduis server for Active Directory
Rasika Nayanajith
Refer below for Autonomous AP config with external RADIUS. I have used ACS as my RADIUS server in this post
https://mrncciew.com/2013/11/14/autonomous-ap-with-external-radius/
Rasika
*** Pls rate all useful responses ***
Hi - I can now see my SSID but its only giving me an option to enter a password on the SSID, where as I want to enter a Username\Password for the SSID:
Config below:
ap#SHOW RUNNing-config
Building configuration...
Current configuration : 3349 bytes
! Last configuration change at 03:31:00 UTC Wed Apr 17 2013
version 15.3
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$m3qn$IZRC9XHSNm7e0Qfs5NFaf/
aaa new-model
aaa group server radius rad_eap
 server name BMI-VADC1
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap1
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods1 group rad_eap1
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
no ip source-route
no ip cef
dot11 syslog
dot11 vlan-name MOBILE vlan 20
dot11 ssid BMI-MOBILE2
   vlan 20
   authentication open eap eap_methods
   authentication network-eap eap_methods
   mbssid guest-mode
no ipv6 cef
username Cisco password 7 032752180500
bridge irb
interface Dot11Radio0
 no ip address
 encryption vlan 20 mode ciphers aes-ccm
 ssid BMI-MOBILE2
 antenna gain 0
 stbc
 mbssid
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio0.20
 encapsulation dot1Q 20
 bridge-group 20
 bridge-group 20 subscriber-loop-control
 bridge-group 20 spanning-disabled
 bridge-group 20 block-unknown-source
 no bridge-group 20 source-learning
 no bridge-group 20 unicast-flooding
interface Dot11Radio1
 no ip address
 ssid BMI-MOBILE2
 antenna gain 0
 peakdetect
 no dfs band block
 stbc
 mbssid
 channel dfs
 station-role root
 bridge-group 1
interface Dot11Radio1.20
 bridge-group 20
interface GigabitEthernet0
 no ip address
 duplex auto
 speed auto
 bridge-group 1
interface GigabitEthernet0.20
 bridge-group 20
interface BVI1
 mac-address 7cad.74db.6ee9
 ip address dhcp client-id GigabitEthernet0
 ipv6 address dhcp
 ipv6 address autoconfig
 ipv6 enable
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius server BMI-VADC1
 address ipv4 10.52.10.1 auth-port 1645 acct-port 1646
 key 7 1211001B1E045D56797F
bridge 1 route ip
line con 0
line vty 0 4
 transport input all
end
ap#
