To Bridge, or not to bridge DHCP for Hreap?
tahequivoice
Level 2
Level 2
I am doing an Hreap, AKA FlexConnect setup with the WLC in a Colo. In the setup it asks if I want to bridge DHCP.  Which will be a better solution to this, Proxy or Bridge?  The DHCP will be coming from servers local to each location, there are 5 locations with 2 SSID's each.
Stephen Rodriguez
You'll want ti bridge the traffic. Just make sure you have the ip helper configured if your shop is on a different subnet from the VLAN the client is on.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Would the helper be on the router interface of that VLan then?
One the L3 interface.  So whethe that's the VLAN or the sub-interface on the router, either should work
HTH,
Steve
HTH,
Steve
OK thanks, I will give it a try and see how it goes.
