What type of memory is used in the cisco wireless controller 2504?
diegeo
Hey guys, I just received a 2504 wireless controller from a branch without the memory and the flashcard. The memory seems to be similar to a sodimm but larger, does anybody know what type of memory is it? The flashcard I assume is a 1Gb standard. Thanks.
Sandeep Choudhary
Bot the WLC and look at the boot up process....
Board Revision 0.0 (SN:xxxxxxx, Type: AIR-CT2504-K9) (P)
Verifying boot loader integrity... OK.
skip
CPU Cores: 4
DRAM: 1024 MB
Flash: 32 MB
Clearing DRAM........ done
Network: octeth0', octeth1, octeth2, octeth3
' - Active interface
E - Environment MAC address override
CF Bus 0 (IDE): OK
IDE device 0:
- Model: 1GB CompactFlash Card Firm: CF B612J Ser#: xxxxxxxxx
- Type: Hard Disk
- Capacity: 977.4 MB = 0.9 GB (2001888 x 512)
Dont forget to rate helpful posts
Hi, actually what I need to know is if it is a sodimm DDR4 memory or what type of memory is it. For that you need to open the unit and take a look at it. Also if you can upload a picture would be great. Thanks.
diegeo
Ok finally found it, I must say I never have seen this type of memory...
can you tell me the model number or what the ram is called i cant find anything please help me
