9800 controller
cisco8887
Level 5
Level 5
all,
Cisco 9800 controller supports wave 2 APs such as 2800 and wifi 6 such as 9100.
This is just the ap models supported but my guess is they can still run in 802.11b or a to support old handheld devices right despite aps being wave 2 or wifi 6?
based on this my answer would be yes
Q.  Will Wi-Fi 6 be backward compatible with previous generations of Wi-Fi?
A.   In Wi-Fi 6, all devices must also support all the mandatory 802.11a, b, g, n, and ac modes of operation. This ensures that Wi-Fi 6 Access Points (APs) and clients are backward compatible with legacy APs and clients.
Mark Elsen
-  The answer is indeed yes.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rasika Nayanajith
As you guess it correctly, simple answer is yes.
However, do you want to keep 11b devices in your network? If you do that will significantly degrade overall wireless performance.
"This is just the ap models supported but my guess is they can still run in 802.11b or a to support old handheld devices right despite aps being wave 2 or wifi 6?"
I would not enable 11b rates (1,2,5,5,11Mbps) on my 2.4GHz network. If you have 11b only devices, I would suggest upgrade them rather than sacrificing everybody's WiFi performance by bringing those onto your WiFi networks. Here is a Cisco blog talk about same topic
https://blogs.cisco.com/networking/bring-out-yer-dead-5-steps-to-eliminate-802-11b-from-your-networks
Here is a good document that covers Cisco Road to WiFi6
https://www.cisco.com/c/en/us/products/collateral/wireless/e-nb-06-preparing-for-wifi-6-ebook-cte-en.html?
Rasika
*** Pls rate all useful responses ***
Agreed - get rid of b only devices so that you can disable the lower data rates.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
