09-14-2019 05:17 AM - edited 07-05-2021 11:00 AM
Hi, I'm doing project for a large company who asked me to order a few Cisco Aironet 1815w APs. Now that I have them I don't know where to download the CAPWAP controller based software to configure them (I'm assuming it is a software app similair to what Ubiquiti uses).
I've been searching heaps of Cisco configuration guides for this, and they always mention using a controller, but never provide any download links on where to get it.
Can someone enlighten me on this.
09-14-2019 11:52 AM
https://software.cisco.com/download/home/286311152/type/286289839/release/8.5.105.0
M.
09-14-2019 03:29 PM
Isn't that just the firmware to upgrade the AP to Mobility Express for self-management.
09-16-2019 06:10 AM
Cisco Mobility Express is a virtual wireless LAN controller integrated on 802.11ac Wave 2 access points. Your Cisco 1815w running Mobility Express support up to 50 access points and 1000 clients.
With Mobility Express, you get the most affordable Cisco enterprise-class wireless solution with no physical controller cost, no access point license cost, and no ongoing subscription fee. The rest of controller options (Physical, virtual, cloud) require you to buy them and install.
**Please rate if this response is helpful**
CJ
09-16-2019 03:16 AM
A Cisco wireless controller is something you buy. https://www.cisco.com/c/en/us/products/wireless/wireless-lan-controller/index.html
Either hardware or the software appliance, but either way you'll need to buy it.
The alternative is to stick some of the APs into Mobility Express mode so they act as controllers for the other APs.
09-16-2019 06:50 AM
originally the controller/WLC was a hardware appliance you needed to buy and install in a cabinet.
later Cisco developed a virtual controller/vWLC you could run under VMWare (on a Cisco UCS server) with the same functionality
and last Cisco developed a technique to run the vWLC AND the access point software on a physical access point
the last is called the Mobility Express software image.
(For large environments a physical appliance is still prefered.)
So if you have a physical or virtual controller in your company you do not need to download and run the
"CAPWAP controller based software to configure them",
- you connect the AP to your network
- the AP registers itself to the controller (if network properly configured)
- you login into the existing controller
- from the controller you configure the access point.that pushes cthe configuration to the access point.
if you start fresh in a greenfield, then the you need to som more work.
