WLC in SSO Setup
jegan_rajappa
Dear Folks,
Is it possible to connect Redundancy ports between primary WLC and HA WLC through switch-port instead of connecting directly ?
I have a requirement where dual L3 switches in different building, so connecting copper cable through Redundancy ports directly is not possible.
Note:
WLC Model: 3504
SSO is required, so N+1 model cannot be considered in this case.
Leo Laohoo
Yes, it's is possible.
My controllers are separated by about 20 kms. The Redundancy Port must be in a non-routable VLAN (layer 2 only).
anthonylofreso
Level 4
Level 4
I'm having trouble finding documentation specific to the 3504 WLC. But here are the available options for the other WLCs: https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-1/HA_SSO_DG/High_Availability_DG.html#pgfId-78132
AFAIK,
You mus conecct direcctly the ports. The WLC make a mapping and change the ip addressing for a ip address 169.254.x.x.
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
Leo Laohoo
Excellent, this answers my question, Thanks Leo !
