Michael Durham
Level 4
Level 4
I have a few AIR-CAP3502E-A-K9 access points that I want to change to Lightweight mode.  I did a lot of researching and found that I needed the ap3g1-k9w7-tar.153-3.JAB.tar file or a similar version of it.
I do have that file and I was able to upload it to the 3502E and it does boot up. But, neither radio will come up.
*Mar 1 00:35:37.228: Interface Dot11Radio0: not starting because stop-on-failure set
StreetWalker(config-if)#
*Mar 1 00:35:37.231: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
The radio status shows up but the protocol says down.
I tftp'd the IOS to the AP and then ran the archive command then deleted all of the CAP type files.
Any ideas on how I can get this working correctly?
2 Comments
French webcast-routing
