Rollin Kibbe
At times, it may be necessary to add more resources to the virtual machine Prime Infrastructure runs in.  Following are steps for adding a second virtual hard disk to Prime Infrastructure.
NOTE:  Making the existing virtual hard disk larger is not supported;  only adding an additional drive (or drives) is supported.
NOTE:  Always start any maintenance activity by knowing where the most recent backup is, or creating one.
Step 1.  Shutdown Prime Infrastructure
     SSH to the Prime Infrastructure command line interface as the admin or other administrative user
     primeinfrastructure/admin# ncs stop
Step 2.  Shutdown the Virtual Appliance
     At the Prime Infrastructure command line interface
     primeinfrastructure/admin# halt
Step 3.  Add new virtual hard drive
     a.  Right click the virtual appliance in the VSphere Client
     b.  Select "Edit Settings..."
     c.  Select "Add..."
     d.  Select Hard Disk, then Next
     e.  Select "Create a new virtual disk," then Next
     f.  Enter desired size and location for new virtual disk, then Next
     g.  Select Next
     h.  Select Finish
Step 4.  Power on the virtual appliance
     a. Right click the virtual appliance in the VSphere Client, select Power, then Power On.
Step 5. Login to Prime Infrastructure and confirm the additional disk space
     In the Prime Infrastructure GUI, go to Administration > Appliance to see the additional space
mailingadnan
Great article can you please advise they newly added disk is automatically provisioned to existing storage ? Thanks
John.Gerlach
FYI, I was just informed that it will be automatically provisioned upon the VM restart as follows:
"When you restart the system after step 4, PI will automatically allocate the new disk space with 85% going to the opt volume and 15% going to the localdisk volume. No further manual input will be needed at that point."
Andreas Jaeger
The most important information (I didnt find it in the manuals) is:
Adding disks works well - how many disks can be added like this that all?
(is there a recommended minimum/maximum disksize and/or drive quantity)
Rollin Kibbe
The script onboard will only add 2 drives (for a total of 3).  Adding a drive is intended as a workaround to an undersized system.  If space continues to be a problem, one should probably look at deploying the next size larger .ova.
mbjurlin
Can the onboard script be modified to support 4 drives?  If so, is there a procedure to do that?
shkerry
Community Member
No, you cannot provision it to add 4. If you are in this situation, please take an application back up of your system to an FTP or NFS repository and redeploy allocating the needed space. Once done you can then add up to 2 more drives should you run in to this situation again due to system growth.
I would recommend going to server settings and lowering retention time for data and alarms to necessary time lengths instead of system defaults to save space if this is an ongoing issue.
Ryo Kato
If you want it in linux' way: PI is based on linux, it's a simple disk with LVM. So you can expand the disk in VMWare, then ssh to Prime, become root (login -> "shell" -> "sudo su") and check the status with df, pvs, vgs, lvs.
After that point, use the standard procedure to expand/add/replace LVS/filesystem as you want it.
PS: it's a good idea to stop the prime ("ncs stop" in shell) before doing this operation.
gustm
And what if 3-rd drive wasn''t provisioned except redeployment or manual extension of logical volumes?
Instead of shutting down and powering on, I restarted appliance after "hot swap" addition of drive, but it should not matter to the script. To be precise it's Prime Infra 2.2 (right before upgrade).
